Always good to see another Aussie Das! Heres a couple more pics of the engine with a few bits removed, there the best ones I have, I should have taken more pics whilst I had the thing apart but Anyway..........
ok i'll try to describe it the best I can....
the supercharger is mounted sideways with the exiting side of the supercharger facing the left side where the battery usually is (battery has been relocated to the boot by the way)
There are 2 brackets, 1 for the supercharger itself and the other is for the belt tensioner. The bracket that holds the supercharger itself is the one next to the intake manifold, this one is bolted to the engine at 4 spots, 2 at the engine mount where it bolts to the block, 1 where the oil filter cannister is bolted to the block, and lastly on the intake manifold itself. The supercharger is bolted to this bracket in 3 spots, 1 through the snout of the supercharger (this also holds the other bracket) and 2 at the rear of the supercharger, 1 at the top (you can see this in the 1st pic) and another at the bottom.
The bracket for the belt tensioner is the one that loops over the snout of the supercharger. This is bolted to the block where the altenator bracket is and also bolted to the snout of the supercharger.
Hope that helps Das!
PS.......... Its a roots style blower not a twin screw!
offroadkarter, after having this thing apart I realised what a monumentous job this must have been to get a s/c working properly on this. This would have cost a fortune to get done. I wouldn't of dreamed of attempting such a project in a hundred years! I guess this is why you don't see many supercharged m30's. Even going through mye28 I've stumbled across a couple of failed attempts. But I'm glad somebody did otherwise I wouldn't be with this bad boy!!!
