mooseheadm5 wrote:That first video was so boring I went to get a cup of coffee.
SRSLY.....will get better vids. Now that I know this thing will break the rear loose with ease.....
Jon2830 wrote:You should probably change your sig now because you essentially have an m20 car now
Anyway, nice car and the 5 speed really makes the diesel so much more enjoyable to drive. Its a shame more people don't do this swap. All you really need to do is turn the fuel screw in a couple turns, bring the boost up to around 15psi, delete the emission controls and the car will be even better. Also if you do delete the emission controls (which you probably will when you do an intercooler) I would take off the intake and clean it, I cannot believe how much build up was in mine when i had it apart to do the injectors. Also since the car started life as a gaser, and now has a diesel wont it not pass inspection in Virginia? or do you guys have some sort of law that says any car that is X number of years old is exempt? IN NJ that car wouldn't pass inspection at all unless you could get it exempted through using classic car insurance.
If only BMW made a big 6 diesel.....
Meh, we don't have emissions here. As far as the gvmnt is concerned it's a 1988 535is. Plus too, I'm putting AQ tags on it, so no inspection whatsoever and permanent tags.
Was eyeballing a tubular M20 turbo mani.....if the TD stuff fits M20s.....M20 stuff should fit the TD.
Really this will be a nice little mildly hotrodded diesel. Plan is to get it all up to snuff and bring to the Vintage next year. Don't think I'll have it together in time for this year.
