FS: 88 528e parts
FS: 88 528e parts
This thread is dead, Jim. Go here instead: http://www.mye28.com/viewtopic.php?f=4&t=131842
lilpoindexter
Re: Achievement Unlocked: I bought a parts car
Post by lilpoindexter »
HMMM...The car looks like it is in good shape. I can't tell from the pics if the pistons are damaged...Maybe it would be worth doing an e2i swap on it, and having a nice beater? :ohyeah:
lilpoindexter wrote:HMMM...The car looks like it is in good shape. I can't tell from the pics if the pistons are damaged...Maybe it would be worth doing an e2i swap on it, and having a nice beater? :ohyeah:
I already have a nice beater... Parts from this will make it better.
I'm not sure where you see "good shape". I a ratty blue interiored, moldy trunked, dinged body, automatic, 528e with 345k hard miles on it.
dsmith
Post by dsmith »
Does the sunroof work? I need all of the cable guts. Cables, and all of the plastic parts attaching the sunroof panel. It's a pain to remove, so I understand if you don't want to do it.
Basically, 15, 25 and 30 from realoem.com.
http://realoem.com/bmw/showparts.do?mod ... g=54&fg=05
dsmith wrote:Does the sunroof work? I need all of the cable guts. Cables, and all of the plastic parts attaching the sunroof panel. It's a pain to remove, so I understand if you don't want to do it.
Hell, I've always wondered how all that fit together. I'll hook the battery up and see if it works. If it does, and I feel the motivation, what's it worth to you?
dsmith
Post by dsmith »
New parts are $200ish. So maybe $75ish depending on your success.
-move the sunroof back a few inches, pop off the front edge of the panel and slide it back.
-close the sunroof and raise it into vent mode. unscrew from the inside and remove. This is where you'll find if the plastic rails are ok.
-remove all of the screws attached to the body.
-use a plastic panel remover to help pry up the metal parts that are double stuck on.
-slide the inner panel all of the way back and remove. it's tricky. go easy.
-follow instructions to extract the cables.
Good luck. We're counting on you.
looks like there's a bunch of bits and bops you can pull and stash away.
Eta power
Post by Eta power »
How much do you want for the diff? I'm interested if it's a 3.46, which it should be.
Eta power wrote:How much do you want for the diff? I'm interested if it's a 3.46, which it should be.
Good question. I'll pull it.
rebelxtnut
Post by rebelxtnut »
How much for the toolkit shipped to 85716?
Oh Wow. What a heap of shit. Your wife is going to puke. How's the trunk roundel?
Gustav129
Post by Gustav129 »
I need the hood hinges.
Are you going to on the nwBMWclub drive to Leavenworth on the 7th?
matchstick
Post by matchstick »
How much for #11?
Does the cluster work? How about the 'input unit on-board computer' that reads out temp, miles, etc.. Backlight on that sucker work?
Each side has a small crack near the front, where it's backed by metal. Rear looks fine. You still want?
dsmith wrote: -follow instructions to extract the cables.
What instructions?
rebelxtnut wrote:How much for the toolkit shipped to 85716?
$25 shipped.
Gustav129 wrote:I need the hood hinges.
I think the hood hinges are beat on this car. Hood really doesn't like opening or closing.
Maybe.
matchstick wrote:Image
How much for #11?
Let me pull it off and post pics first.
Dunno if it works or not. Make me an offer.
dsmith
Post by dsmith »
What instructions?
https://www.bmwtechinfo.com/repair/main/137en/index.htm
54-5 I believe.
They look good so far. See if you can get them out the rest of the way and let me know.
dsmith wrote: They look good so far. See if you can get them out the rest of the way and let me know.
Once the cables are extended as far as they will go they just pull out.
Is this all the stuff you want?
Re: Achievement Unlocked: I bought a parts car (88 528e)
I'm done taking stuff out of the engine bay. Got what I wanted (wiring harness). Some more stuff listed in top post of this thread.
If there's anything in this picture you want, speak up.
I'm also done with the interior. Speak up if you want anything else.
dhdrums
Post by dhdrums »
If #4 is good, how much for it?
dhdrums wrote:If #4 is good, how much for it?
Not good. Sorry.
dsmith
Post by dsmith »
Yes. If you don't see any cracks in the rear plastic parts, I'll take it. I'll take the shift knob too if it still secures well. And the rear window lockstrip. You can send the front too. I just need enough to do the rear. You can email me with details.
Thanks.
Jake D
Post by Jake D »
Mr. K.
I'm interested in the Upper Firewall Cover!!
Can you hold it for me if it's still available? I'll PM ya.
Jake D wrote:Mr. K.
For you?
YES.
Nick C.
Post by Nick C. »
Interested in both taillights. The cracks in the left side taillight are only in the turn signal section or are there more not pictured? I don't mind cracks on either light so long as its just that amber part.
dsw99a
Post by dsw99a »
is the fusebox cover taken yet?
matchstick
cek wrote:
matchstick wrote:
How much for #11?
I do a combo with #11 and the computer assembly there. If the backlight doesn't work, I guess I could use the hazard and defroster buttons because mine kinda stick.
I'll wait for the pics and throw you an offer.
oldskool wrote:Oh Wow. What a heap of shit. Your wife is going to puke. How's the trunk roundel?
Trunk roundel sucks. Sorry.
Nick C. wrote:Interested in both taillights. The cracks in the left side taillight are only in the turn signal section or are there more not pictured? I don't mind cracks on either light so long as its just that amber part.
Cracks only in amber on left one. Email me ckindel(at)gmail.com to close the deal.
