BMW 535I turbo (M106)
M106
Post by M106 »
hi guys!
heres is my car and how it looked like when i bought it in 2005
M106 block
cooperring gasket
ported m106 head
M7 camshaft
HD rockers
Stage 2 valve springs
camsync trigger
60mm wastegate
50mm dump
Incercooler 600x300x76
Precision 6265 turbo
throttles from m5 e34 3.8
m5 plenum rebuild
innovate MTX-l broadband
1260cc Precision injectors
Nuke Blackline fuelrail
Aeromotive 13109
Nuke gasfilter
2x044 bosch fuelpumps
intank Deutchwerk dw301
Autronic Smc
Autronic solenoid valve
MDS Digital 4 plus
3 st accel distrubitor
8,5mm msd ignition cables
to much rust
goodbye rust
frontspoiler
back home
how it looked back in 2007
M106
Re: BMW 535I turbo (M106)
Post by M106 »
a bit update
controll of autronic harness
welded AN in the block
drill the hubb to put a extra pin
build a gauge holder
a bit to shiny =/
M106
Post by M106 »
how to make valve relief on the pistons
M106
Post by M106 »
the head is finish
just waiting for a new oil pipe from bmw
s38 throttles
M106
Post by M106 »
coopering gasket and arb bolts
M106
Post by M106 »
new painted
M5 plenum
bolted on =)
M106
Post by M106 »
some performance parts =)
M106
Post by M106 »
halfway
Nice restoration!
This is cool.
M106
Post by M106 »
marc79euro645
Post by marc79euro645 »
Pinning the crank nut is an interesting idea. I broke several wood ruff keys until I welded a 2x2 pipe on an old damper to lock the motor. Then red loctite and a 6' cheater bar finally solved it. I really like the ss hoses. Nice job!
marc
George
Post by George »
Any close ups of the modified thermostat housing off of the motor?
M106
Post by M106 »
stainless steel exhaust
M106
Post by M106 »
dyno day!
M106
Post by M106 »
ZenitramNaes
Post by ZenitramNaes »
This is great, loving the Nuke parts.
Good & Tight
Post by Good & Tight »
Nice build, very clean with lots of power. How is the M7 cam at idle..?
M106
Post by M106 »
Good & Tight wrote:Nice build, very clean with lots of power. How is the M7 cam at idle..?
like this =)
https://www.youtube.com/watch?v=q428bK1evhw
Shadow
Post by Shadow »
i know this is super old but i just want to say WOOOWWWWWW.
look at the redline.
too me thats proof the m30 manifold is a massive restriction and there should be
an aftermarket one but there isn't.....
Doesn't the stock one just DIE after 5.5k?
russc
Post by russc »
ok, now Im really confused, thats not a 4v engine, holy shit, I missed that big time. That is pretty astounding. 655whp from a M102, thats 3.2l, right? what the fuck. If I has to say, I would say the stock manifold is a huge restriction, in this example.
RussC
russc
Post by russc »
so whats and "M7" cam?
M106
Post by M106 »
russc wrote:so whats and "M7" cam?
a swedish company that makes race camshafts
BMW M30 M7: 300/110/11.2/3.0
Hffvdbl
Post by Hffvdbl »
What's the name of the company?
Hffvdbl wrote:What's the name of the company?
Catcams
M106
Post by M106 »
www.enem.se
I'm curious, what prompted the need for relief cuts in the pistons? Or was this more for safety.
M106
Post by M106 »
Nebraska_e28 wrote:I'm curious, what prompted the need for relief cuts in the pistons? Or was this more for safety.
with the M7 camshaft, the valves will touch the pistons
:shock: Wow, that's alot of lift! :cool:
