Looking for known good power steering pump. According to realoem, the part number is 32411141243 and any E30 M20 pump will work. PM with price shipped 19067
THX
WTB - E30 M20 PS pump
Re: WTB - E30 M20 PS pump
Is it physically different than the M30 pump? I've got a bunch of those as I'm sure you do also.
Realoem calls it out as E30 M20 only, probably due to hose inlet/outlet. The part I found more surprising is that it's not iX specific.
I took a look at the cross-referencing last night and it's a bit confusing to me. For example, the M20 eta pump (32 41 1 133 969) cross references with all e28's and all e30's including the ix.
If you have a bunch of PS hoses with various fittings on them then it's just a matter of cutting and brazing a particular fitting on to create a hose that fits.
What am I doing wrong then?
bmwfans is reporting something else then. I guess the definitive source is RealOEM?
The definitive source will be my garage! I have a bunch of M30 pumps to try out, assuming the bar rating is the same.demetk wrote:bmwfans is reporting something else then. I guess the definitive source is RealOEM?
