Car has been doing this intermittently for about a year and a half, but recently has been much more prominent and the shaking has gotten worse. Clutch has about 20k miles on it, but I'm not sure if the previous owner replaced the slave or master cylinder or other components of the clutch system during that time.
My question is, how sure can I be that this is clutch related or driveshaft related? I have had the intermittent slight shudder while accelerating from low RPM since I've had the car. Very noticeable in first and second gear, but that's obviously when my foot is off the clutch pedal.
I'm hoping that since this only happens when the car is cold that this could give me a clue of where to look first. Clutch pedal feels fine and there is absolutely no indication of a problem after about 10 minutes of driving.
UPDATE: Clutch pedal just went to the floor. On my way back to mr. searchy.
UPDATE 2: Clutch helper spring unseated itself, causing it to dig into and puncture the master cylinder hose while the clutch pedal was depressed. Swapped the new master and slave and hose line and I'm up and running. Noticed a well worn transmission mount while under there, and will replace the pair to see if the shudder goes away.
