Help: Tips needed on removing catalytic from manifold
Zeshin
Post by Zeshin »
Hey all,
I'm trying to replace my catalytic converter.
I'm having loads of trouble getting at the 6 nuts holding the two catalytic converter down pipes onto the exhaust manifold. They are rather seized on there.
Is there a trick to getting the leverage needed to break free those nuts?
What tools and from what angle have you guys managed to get those nuts off?
Thanks in advance!
Swivel socket and long extension with breaker bar from beneath.
Zeshin
Post by Zeshin »
Kyle in NO wrote:Swivel socket and long extension with breaker bar from beneath.
Nice! I forgot about trying to use a swivel socket on there...
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
I'd also recommend soaking the studs and nuts with PBlaster or your favorite penetrating lubricant for a few days before trying to loosen them.
This. I got a 14(?)mm swivel socket from Sears for about $4, and put it on a 12" extension, and was able to crack them loose with no penetrant. Wouldn't hurt to spray some PB Blaster or Liquid Wrench on them though. :up:
Zeshin
Post by Zeshin »
Cool, it seems like swivel socket, breaker bar and PB is the way to go! Thanks!
tn535i
Post by tn535i »
Maybe a little to late to add but be sure that it is a 6 point socket and not a 12. 12's too easily round the nuts off.
Cactus
Post by Cactus »
A propane torch will help loosen about anything. If your exhaust is as badly corroded as mine, heat may be your best friend.
Ditto on the 6 point.
Zeshin
Post by Zeshin »
Thanks for all the helpful tips!
