Which Sanden AC compressor??? ANSWERED!
Posted: Apr 25, 2013 9:05 AM
by DJM1986-5
Everyone says replace with a Sanden SD508 or 709...but those are the old Frame #s superseded by the newer better designs SD5H14 and SD7H15. My 535 already has the Sanden bracket installed. What no one seems to communicate in any threads is what # of SD5 or SD7. There are numerous models underneath the SD5 and 7 denoting different capacities, mounts, etc etc. I have found that SD5H14 #6664 seems to be the choice if using the SD5 series (found this on RV3 for E30s), but I'd like to use the 7 series that has a little more capacity for my E28. Does anyone know the correct # for the SD7 Sanden compressor?
Posted: Apr 30, 2013 12:28 PM
by DJM1986-5
So here's the answer in case anyone has sourced the Sanden bracket and/or is replacing their Sanden compressor.
The new Sanden models -
SD5H14 replaces the old 508 series
use model # 6664 or 4510
Ear mount for use with Sanden bracket
Clutch pulley diameter = 132mm
Groove type = 2A
Thread size = 3/4 x 7/8
Oil Qty = 210cc
12 Volt
Inside ear mount dimensions = 83mm
Bullet type connector
SD7H15 replaces the old 709 series
use model # 4664
http://www.sanden.com/productsearch.php
Groove type = 2A
Oil Qty = 240cc
12 Volt
Packard and Bullet type connector
Sandens come with oil in them.
For additional information go to sanden.com. There are also a lot of Chinese models called Sanden "style" compressors. They of course are cheaper and may work just as well, just be aware they are out there. Looks like they copied the US version exactly as they do with so many things.
I'm ordering my stuff from AC Parts Warehouse in TX
972-772-5502 - call to order, do not use the website as it's under construction and is difficult to navigate.
Posted: Apr 30, 2013 1:53 PM
by DJM1986-5
They are also checking on the availability of mounting kits for M20 and M30 motors as they seem to be discontinued.
Posted: May 17, 2013 8:15 AM
by Durden
I would love to hear what comes of this - may need a Sanden soon for my M30 engine.
Posted: May 17, 2013 8:01 PM
by DJM1986-5
I have found a local guy that has a warehouse of NOS. He has a Sanden mount. Mid June I'm planning a trip to investigate. He has no inventory list, but I tested the water on 3 diff e28 parts and he had them all. He has stuff for m1s through e34. I hear junkyard are a good source but have yet to run across a sanden mount.
