That new engine looks like it cleaned up pretty nicely. What all did you do to it?
Looks like you have a new water pump... the eta's water pump differs slightly from the i's pump. The eta doesn't have the extra pipe nipple coming off the side. That came up in another thread about putting an i engine in an e28; the e30s and e34s that used that engine had a different coolant expansion tank configuration... From the looks of your engine bay, you must be planning to keep the stock expansion tank; if that extra nipple isn't used in your setup, I suppose it could just be capped off or something.
I also have an M20B25 that's going into my eta, and am planning to just use the eta pump (I already have a fresh one) and eta cooling bits.
As for your question about the clutch, any idea how long ago those parts were installed & how many miles are on them? The clutch plate looks to have some life left to it, and should last a while, provided you treat it well. The pressure plate can be hard to judge. When they get old, I'm told it takes more effort to disengage the clutch. Also, if you do use those parts, I'd at least put in a fresh throwout bearing. Not terribly expensive, and would help extend the time until having to pull the transmission again.
