How does one go about removing the starter motor? There is not enough clearance for a shallow 17mm socket nor a box end of a wrench to fit over the bolt. I can fit an open end on the bottom bolt but nothing on the top one.
Use the box end from the tool kit (really thin walls) or grind the socket so it is as shallow as possible while engaging the whole nut and tapered toward the ratchet end.
