Long intercooler piping
Patrick McHugh
Is there any disadvantage to placing the intercooler radiator far (+10ft) away from the heat exchanger?
The E28 is short on space up in the front and i'm considering something silly.
Patrick McHugh
They're a little over 15 feet bumper to bumper if memory serves. The only downside I can think of to this scheme is the plumbing and how you'd get adequate airflow over the heat exchanger. Depending on exactly where you're thinking of mounting it, there might be other downsides like susceptibility to being hit by road debris.Shadow wrote:Is the car even 10 feet long?
What are you plotting?
Patrick McHugh
I was going to try to find some space in the rear behind the RH axle for a free air cooler or build a small box in the trunk or under the rear seat with a fan pushing air through SCAT tubing to it. The spare tire well would be a perfect place to create such a thing but I just can't loose the spare given my history of poor luck.Jeremy wrote:They're a little over 15 feet bumper to bumper if memory serves. The only downside I can think of to this scheme is the plumbing and how you'd get adequate airflow over the heat exchanger. Depending on exactly where you're thinking of mounting it, there might be other downsides like susceptibility to being hit by road debris.Shadow wrote:Is the car even 10 feet long?
Patrick McHugh
I believe BMW would put some coolers in the back of the car if you do some research. Such as the CSL, on that note I think it was utilizing the large flares for this. I've seen people make aluminum boxes for like the trunk and run fans and napa ducts. It would be a ton of work no matter what IMO. Also check out Toyota MR2 "Trunk intercooler" It is a popular modification for them and it may give you some design ideas.
Patrick McHugh
Awesome! Thanks!Scottinva wrote:I believe BMW would put some coolers in the back of the car if you do some research. Such as the CSL, on that note I think it was utilizing the large flares for this. I've seen people make aluminum boxes for like the trunk and run fans and napa ducts. It would be a ton of work no matter what IMO. Also check out Toyota MR2 "Trunk intercooler" It is a popular modification for them and it may give you some design ideas.
Bill in MN
There isn't really a whole lot of airflow under the car if you are thinking of putting a heat exchanger back there. You would pretty much need to do some ducting to get air to where you want it, which means cutting up the car (you don't want to do that.) I'd do it to an E30 coupe, because you could run ducts to the rear quarter windows, but your car is too nice to hack up when there are perfectly good ways of doing it otherwise.
Patrick McHugh
Patrick McHugh
