Problem with brake lights, power windows, power sunroof.
Aaron_Tupper
i have a problem with brake lights, power windows, power sunroof. i replaced the fuses and they still do not work. Anyone know why?
TheLazyDog
Aaron_Tupper
TheLazyDog
Did the new fuses blow? Was there anything wrong with the old fuses? Do you have power at the fuses? More details of the problems with each would make it easier to help you. From your replacement of the fuses I would assume that you are experiencing that all of these are not functioning.
If this is the case,
You need to see if you have power at the brake light switch and if it is working.
Are you sure the breaker for the power windows is plugged in and in the correct position.
As for the sunroof as that is the least critical, lets come back to it later.
