A fellow Academite (the one who owns an E30 M3 Evo II) has an Alfa problem, it's like an e28 problem, but with Italian engineering. Recently he acquired an Alfa 75 (not sure of the year), it's red, automatic, and apparently 1 of 5 left in the country (I wonder why...
Being Italian, Alfa decided to make the automatic cars have SLS, but not the manual cars... so, of course, it's broken and leaking, so my first job was replacing the shocks and springs, and running a loop hose between the reservoirs, keeping the system flowing and not "blowing up" as I was told it would... With that done, I moved on and changed the oil, replaced the filter, and did some general maintenance.
Moving on to after the MOT, I wasn't present for the first test. The MOT guy didn't notice that the wheel nuts were loose, wobbled the wheel, and said "wheel bearing needs doing" so, as I was told I replaced the bearing, then connected the dots about the bolts. Also on the "fix list" was the exhaust, so newish SCS rear section went on, it put up a hell of a fight, but I had hammers on my side and won in the end
Fighting back, after about 10 minutes stopping blood, not serious, but it bled like crazy:
Followed closely by new center rubber mounts for the exhaust, it was hanging a few inches too low, and scraping over speed bumps. Then finally I moved to the one bit I didn't want to do... The power steering/SLS system leaks needed to be taken care of, and this is where it gets... fun.
I trace the main leak at the front, to the delivery line to the rear for the SLS (now not needed). The line is around 15ft long, it runs from the very front of the engine bay, all the way to just inside the rear bumper. Because it'd be a complete pig to remover and replace, I instantly think about throwing a bolt into the exit hole in the pump, and just removing all the SLS crap. However, Tristan has some Alfa "gurus" who say this can't be done, things blow up and it's not good... I fail to see the reasoning behind it, as it's perfectly logical to me (see question at end of thread).
Here's the pump, the SLS line is the furthest forward, and is not very big, to me perfect for pluggin:
The next option is to run a new hose right back to the reservoir, as there is already a return line for the completed system, this made sense. Also a no go, apparently the pump needs strain on it to opporate correctly... ok, that kinda makes sense, but what about a baffle in the new hose to recreate the resistence? They had no idea if it would work, and maybe if the leak (now fixed) returns, we'll give that a shot. My third thought was replace the pump with a manual cars pump (only two outlets, not 3, since no SLS in manual cars) but they're rare these days... seems like it's just hitting a brick wall everywhere I turn to try to do this properly.
Oh well, the leak is stopped, with copious amounts of quicksteel, I covered the leaking area and fixed it that way.
Rather long, possibly boring thread, but thought I'd share my alfa experience, and ask one little question: Why can't I throw a bolt in the 3rd outlet, thereby stopping the flow of fluid, and essentially creating a 2 outlet pump?
Oh, and they have torsion bar front suspension, and inboard rear brakes, how cool is that!
