533i Tire Pressures
JasB
533i Tire Pressures
Post by JasB »
Any thoughts as to best tire pressures to run on the 533i for a DD?
Thanks,
Jim
You need to specify what size wheels and tires, what type of tread, etc.
JasB
Post by JasB »
Minor detail! The tires on the 533 are 205/70/14 Kumho Solus KR 21 M&S.
Thanks,
Jim
I'd go around 34-36 and see how it feels.
JasB
Post by JasB »
Thanks for the info...I was running 25 all around and that seems to be a little bumpy in the ride, but I'm thinking it's probably the the tires.
Thanks
Jim
25 is darn near flat. There is a recommendation on the driver's door jamb for an average tire.
Post by Kenny Blankenship »
I'd try 33 front 34 rear.
What would possess someone to run 25 psi in a road tire?
JasB
Post by JasB »
Sorry - I meant 35. I guess I'm losing it (assuming I ever had it).
Jim
BMW specified 33psi per axle for up to four persons and 36psi for "heavier loading." They recommend keeping the spare tire at 40psi.
Best,
No you didn't... :laugh:
What's the tire say?
JasB
Post by JasB »
Pressures noted on tire usually are the max load ratings.
mechacode
Post by mechacode »
I usually stick to 36, 38 if I'm going to drive a long distance to eek out a little better mpg.
mechacode wrote:I usually stick to 36, 38 if I'm going to drive a long distance to eek out a little better mpg.
And wear out the center of your tires. That works well.
mechacode
Post by mechacode »
:rofl:
Smooth tires create less friction and thus return better fuel economy, right?
Smooth tire, smoooooth ride, baby.
I like my tires the same way I like my women. . .
Nanajoth
Post by Nanajoth »
oldskool wrote:I like my tires the same way I like my women. . .
Flat and bald?
Inflatable?
Filled with a bicycle pump?
Worn on the inside...
Though you can get slightly better gas mileage with 35+ lbs of air, I find it causes wear in the center of the tire, especially at the rear (assuming your camber is at stock settings). This has been true of all my old E12s, E23s and E28s. The 32 to 34 lb range seems to work best.
David Hunt
Post by David Hunt »
Mounted AND balanced?
Post by C.R. Krieger »
Kyle in NO wrote:What would possess someone to run 25 psi in a road tire?
Yokohama A-008. That's what.
Flat and bald?
Oh Yous guys . .
I like 'em black and shaved!
I run about 32-35 depending on my mood. 32 is a good soft ride and decent in rain. 35 is good for mpg. I run stock 195 70 14 3 season tires. 99 % of the driving is round town.
You run 165/70R10 (not a typo) Mini Cooper tires on an e28? :dunno:
alijonny
Post by alijonny »
Rated to take at least 1000lbs of your load?
Yokohama made them in a variety of sizes. Mine were 205-55/14, IIRC - and not on a BMW.
C.R. Krieger wrote:Yokohama made them in a variety of sizes. Mine were 205-55/14, IIRC - and not on a BMW.
I believe you're thinking of the Yoko A008r. The Yoko A-008 is a very specific tire for a very specific fitment. It only comes in one size.
I'm pretty sure it didn't in 1987.
mechacode
Post by mechacode »
Unless of course you have blizzaks on that are rated at 44psi. :popcorn:
