Dieselboost's 524compoundTD
couple 524td videos from 1/4mile
my friend car, engine is mildly modified
big "chinacooler", littlebit modified dieselpump, holset 3fd from 70s tracktor with 1.5bar boost, special exhaustmanifold. bigger electric fan.
3.5" straitpipe, sachs race clutch (228mm).
engine is littlebit powerless in some areas, whe had big troubles with engine adjusments. (engine was in parts couple hours before show)
but it worked quite nicely. little bit trim and it goes faster.
exhaustpressure was lower than boost, that was very nice
and engine wasnt overheating anymore.
vids.
http://www.youtube.com/user/boostturbo# ... qafLBzxUfA
http://www.youtube.com/user/boostturbo# ... 59WPe4XAKw
vids.
turbine exducer is 65mm. with small chamber a/r text is removed so whe dont know that.
but problem in that type charger is very old and compressor wheel is poor and it will surge too early.
compressor wheel is 55mm
pressure was taken from exhaustmanifold with normal airpressure gauge.
in my own car there is a exhaust temperature gauge too.
fun with my friend e28 524td, cars owner was the camera man and i was the driver
driving in track was very exciting because this was my first time.
http://www.youtube.com/watch?v=yN-ygvLskOk
http://www.youtube.com/user/boostturbo# ... UXzShgHqtg
hi.
mild engine almost done...
first start with new turbo.
http://www.youtube.com/user/boostturbo# ... YQZFwz1TBQ
Yeah! first test drive completed without bigger problems, only one waterhose was broken and i must get a new one.
sorry...only gentle driving this at this time...
my friend said that my diesel sounds like a cummins
here is the vid... http://www.youtube.com/watch?v=dS3IYvYnuTQ
Here is new burnout vid about my friend car... its e28 524td too.
http://www.youtube.com/watch?v=gqM2pYon0is
Fuck!
Oil leak from head gasket.
this is just irritating
it is mystery what is wrong...
head is machined, bolts are new, gasket is new and gemented with vht gasket gement.
and all work is done by the book tactic
and me and my friend are both educated car mecanicals.
this is weird...this is not first gasket what i had changed.
Ok. here is new burnout video of my 524td
there was huge problems with fuel, ip was taking air while doing burnout....i will make few modifications to fueltank to terminate this.
http://www.youtube.com/watch?v=v-W2ypNTRDY
Dear,
nice to see you bimmer is running. Good dyno results, they are close to my first results after my restart. at the first dyno measurement i have had also lost aproxximate 100Nm torque, which was caused by a pump failure. From what i have seen this should be near of the upper end with the stock injection pump for the m21 engine, what boost pressure have you run at the test?
I shedule to repiar my failed clutch in the next month and will then go ahead with 12mm plunger and camplate from a iveco pump. My goal is to find another 40hp to get 240hp, do you still shedule 300hp for you engine?
By the side for bimmer looks quite nice, i also love the "tractor" sound without muffler. I have drove my car over the last summer also with "straight pipe" exhaust and loves to floor it with open window. Best is, to stay with low rpm than it really sounds like 8ltr engine displacement and when it was pulled hard, it is likely to hear the turbo.
Good look and best Regards
Alleslowbuged
Best regards
Alleslowbuged
Best regards
at this time power goal is about 350hp but that engine is very heavily modified.
i just came to home from carage
now there is the 12mm rotorheadpump and i found that my 524TD goes nuts with that
allmost shitted to pants....that power is awesome
when is was taking 191hp from stock ip there was 1.9bar boost...it is too much but time was running out and i was thinking that makes maximum power.. so it was more easy to run with big boost.
now i have 2.0bar boost with 12mm rotorhead...
engine temperature stays under 90C
exhaust temperature stays under 700C
exhaust pressure stays same what the boost is.
i think this is big success from me
now i must buy a new waterhose...again OLD waterhose exploded.....im thinking how stupid i am when i use those
yes i can...not now but soon.Zubcho wrote:Something new about the project?
Can you tell us the detiled list of the parts that you used and some prices of the parts
btw... mild engine exploded...
caused by wastegate malfunction boost was about 4bar and headgasket explodet out...
feels little bit stupid because that happened....so next time i will keep eye on gauge...
interesting thig is that my engine last for 15min before explosion...and water temperature was 85-90c so cooling works fine...
ext gas temperature was about 800c-900c
and base engine was stock..
now im changin new gasket and ready to roll again...
at same time im working with super engine....
Stock...because i have one spareFrybrid 524td wrote:What new head gasket are you using? Anything special or just a stock gasket?
mls gasket is good...but for this engine it is too expensive..
my friend 524td engine is now worked over one year with stock gasket.
power is about 200-250hp and boost 2bar
Fun with my friend car...(me driving)
1.6bar boost
i can reveal...this car is builded from junkyard/trash parts
turbo is now new...not anymore 3fd..
now there is Garrett t04b/t04e hybrid...ofcourse turbo parts are from junkpile
so littlebit imagination and this you can get for cheap
http://www.youtube.com/watch?v=lIV3v1V7__Q
1.6bar boost
So... i repaired my junkpile again.
cyliderhead was totally like a corkscrew caused by heat.
but now it is machined again and engine is running good.
there is one stupid thing to change....there is now fuel pump in tank to getting more fuel for ip but hoses are wrong...
pressure is going to re-circulatingline and leaking lot of fuel out.
In my ip is cummins 12mm rotorhead.CoyoteStarfish wrote:I hate to make you repeat yourself DieselBoost, but can you go over the modifications you've made to your injection pump again?
I'm getting ready to look for parts to modify my injection pump (12mm head and rotor, 2.8 or 3.2mm cam plate, etc)
but there is adjustments wich i cannot tell anything...because guy who made my ip cant tell me anything....secrets....he say.
but use stock cam plate... i use that too. there is only problems if you use steeper plate.
steeper plate fits nicely to low rpm engines like cummins.
just thinking if my ip cant produce fuel amoun what i need, then i will use mb 300tdt ip maded by mynädiesel with 7mm plungers.
