And why am I not surprised given what his other cars are like.e28Sean wrote:It's soooooo preeeetty!cek wrote:
I think it's something about E39 suspensions. I had a wear pattern very much like that, but not quite so extreme on one tire. The inside edge was trashed but the rest of the tire looked ok. Asked the tire store to give me their opinion as to if an alignment was needed, but that request, along with some other things, got lost in transit. I just did one tire since the rest were in excellent shape. Fast forward a year later and another tire looked like that. This time it was 4 tires and an alignment. With over 200K on E39s before that I'd never run into that before, although many speak of poor tire wear on the chassis. A coworker couldn't keep tires on his and had the shop take as much of the negative camber out of it as they could. Looked odd afterwards. I tried to explain it was toe causing the problem, not camber, but couldn't get him to understand.vinceg101 wrote:E39:
Last Thursday: New Tires (Dunlop Signature HP's) after this happened the previous weekend:
These were the two rear tires; one came apart at speed on the freeway and the other was on its' way to doing the same thing.
Specifically it's the E39 factory Sport Suspension that is guilty of massive tire consumption; it's a well documented and BMW admitted issue. One preventive measure is dial out the rear negative camber (as well as making sure the toe is correct also) by a few degrees; it helps but doesn't solve the problem. There is a point at which if you dial it out too much, you defeat the ride performance; I have to research that before next week when I have to re-align everything.Mike W. wrote:I think it's something about E39 suspensions. I had a wear pattern very much like that, but not quite so extreme on one tire. The inside edge was trashed but the rest of the tire looked ok. Asked the tire store to give me their opinion as to if an alignment was needed, but that request, along with some other things, got lost in transit. I just did one tire since the rest were in excellent shape. Fast forward a year later and another tire looked like that. This time it was 4 tires and an alignment. With over 200K on E39s before that I'd never run into that before, although many speak of poor tire wear on the chassis. A coworker couldn't keep tires on his and had the shop take as much of the negative camber out of it as they could. Looked odd afterwards. I tried to explain it was toe causing the problem, not camber, but couldn't get him to understand.
And the 2 year old took an Uber home?SPF2006 wrote:Hauled in the X3, along with spouse and two-year-old, in one trip:
- 15 cubic feet of topsoil
- 7.5 cubic feet of river rocks
- 18x18" slab of slate
- (2) 30"-diameter planters
- 20 lettuce plants
- 3 tomato plants
- 4 Italian herb plants
- 2 ornamental grasses
- 1 butterfly bush
Used pretty much every square inch of the hatch and back seats, but got it done, raised bed construction now underway.
Capri 13 made by Catalina. I jokingly refer to it as a Laser for old farts.funfunfer wrote:Laser 2?
lol. I aged and bulked my way out of racing on small boats too but I still enjoy a leisurely solo cruise around the bay on a nice day.funfunfer wrote:Nice looking boat! I long ago aged and bulked my way out of small boats. Crewed a Laser 2 until the 125lb skipper couldn't keep my fat ass out of the water.
In your pic, is that B.A.D. playing or the Village People?cek wrote:Three steering wheels in as many days. They finally found one without fabric pulling up. And, as a bonus, they installed straight, unlike the second which was crooked.
How could a tech live withhim/herself leaving a wheel like this?
I figured if anyone would notice, it would be youKarl Grau wrote:In your pic, is that B.A.D. playing or the Village People?cek wrote:Three steering wheels in as many days. They finally found one without fabric pulling up. And, as a bonus, they installed straight, unlike the second which was crooked.
If you're lucky... It might just be the oil filter housing gasket. I was convinced for a couple of years the pan was leaking on the 00 528it, even changed the front crank seal, but it turned out to be the filter housing. Still not a fun job, but not as bad as the pan.Karl Grau wrote: It looks like the oil pan gasket leak has gotten worse. Now there's a job I'm looking forward to.
I'm not lucky. I already did the oil filter housing gasket.Mike W. wrote:If you're lucky... It might just be the oil filter housing gasket.
Oh well, I tried.Karl Grau wrote:I'm not lucky. I already did the oil filter housing gasket.Mike W. wrote:If you're lucky... It might just be the oil filter housing gasket.![]()
http://www.mye28.com/viewtopic.php?f=7& ... =#p1317398
I'll have to have a look at mine. Are there any tell-tale ways to determine which it is? I was resigned to living with my oil leak, but I might be willing to have a go at the filter housing.Mike W. wrote:If you're lucky... It might just be the oil filter housing gasket. I was convinced for a couple of years the pan was leaking on the 00 528it, even changed the front crank seal, but it turned out to be the filter housing. Still not a fun job, but not as bad as the pan.Karl Grau wrote: It looks like the oil pan gasket leak has gotten worse. Now there's a job I'm looking forward to.
Just the usual, clean up everything and see where it gets wet first. Of course I thought I did that but it wasn't on my radar and I guess I didn't look carefully enough. It is a well known problem, even if I was late to the party on it. I should add while it made a mess of the front/bottom of the engine and would occasionally mark it's spot on the pavement, the oil level at change time was always at full. And if you're in that far, and north of 150K and it hasn't been done, you might want to do the coolant pipes along side the block. Of all the E39 cooling system weaknesses, IMO that one's the worst.doug wrote:I'll have to have a look at mine. Are there any tell-tale ways to determine which it is? I was resigned to living with my oil leak, but I might be willing to have a go at the filter housing.Mike W. wrote:If you're lucky... It might just be the oil filter housing gasket. I was convinced for a couple of years the pan was leaking on the 00 528it, even changed the front crank seal, but it turned out to be the filter housing. Still not a fun job, but not as bad as the pan.Karl Grau wrote: It looks like the oil pan gasket leak has gotten worse. Now there's a job I'm looking forward to.
As an aside, when I was in getting the airbag replaced, the dealer offered to R&R the oil pan gasket for $2000. I said "no thanks".
