- Location: Everett, WA -- previously Victoria BC, Canada
Heater Valve Rebuild Kit
took me about 8 minutes..
yay heat! even though we are having a heatwave right now, Im going to be happy in a few weeks!
ordered from http://www.bimmerspecialist.com
best price I could find in Canada at $58 and they shipped it super fast!
Apparently its monsoon season in Central Ohio. I opened the trunk to see if water was leaking in. It wasn't until I opened the trunk.
Then I proceeded to get a towel and dry it up and leave another in there to soak up any more moisture that gets in.
I do, however, need to replace my trunk seal with the brand new one also sitting in the trunk. I just need to get the proper glue needed to glue it down... well that and figure out what the proper glue needed actually is... lets try out that search function...
Last night... Pulled the driver's door panel off & found that the reason the inside door handle disappeared on my son was because he managed to break both mounting tabs off of the thing.
He said the trim piece came off and he was trying to put it back on and the whole handle disappeared. No idea how he did that. But that was two days ago, and since then he's been lowering the window to get out of the car, and at some point the lift mechanism crunched what was left of the handle. New part on order; under $10, so nbd, but still... How'd he manage to do that?
While we had the door panel off we re-greased the window mechanism; it was dry as a bone.
Wow does it work better now!
Instead of wiring in rear fogs to my new euro fog light switch as planned, wired my city lights to the rear fog switch. Now I can have ONLY my city lights on. Before I had them wired into my parking lights.
All of this was done after doing this yesterday to my thumb with my tablesaw.
Found this in the shop after I got back from the ER.
Dude; that's nasty! I'll bet that hurts like anything!ilikemybike wrote:Instead of wiring in rear fogs to my new euro fog light switch as planned, wired my city lights to the rear fog switch. Now I can have ONLY my city lights on. Before I had them wired into my parking lights.
(not really, but... Dave beats a hasty exit to find some kitten pictures to help scrub that image out of his brain...)
