looking at m5 EDIT: bought it: 2791859 is back from the dead
Retro Rust
Post by Retro Rust »
I know I could research this with the search function, but im short on time. Can you tell me any M5 specific things I need to look for while checking the car over?
Things I already know are wrong:
Master cylinder is bad and brakes dont work well,
Alternator is bad, needs to be jumped to drive it
fuse for Pwr windows/tach blows every time ignition is turned on
owner doesnt know if A/C compressor works or not "doesnt have a belt running it right now"
thanks
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
S38 specifics - Cam chain, guides and tensioner inspection/replacement. Is there a lot of noise on start-up?
Everything else (other than the G280 transmission, anti-sway bars and the self leveling rear suspension) are pretty much standard E28 fare.
Rich Euro M5
Post by Rich Euro M5 »
Since it sounds like the engine will start and run, arrange to have a leakdown test done.
Rich
Retro Rust
Found on craigslist. 4th owner was a 21 year old who couldnt afford to fix it. Odometer stopped at 144k, but last service record was 126k about 2 years ago, so I figure it has somewhere around 150K. No rips in leather. Numbers matching, mostly good body, some door dings, has been repainted but was done professionally and seems to be one-stage paint. Some overspray onto rubber trim. Mirrors were painted (thats not original is it?). No wrecks that I could tell. Little bit of rust near license plate lights, little rust on inside of right rear door. Motor started and idled well, no noise that I could tell would mean it needed a timing chain. Motor seemed really tight. It ran like a scolded dog. Tranny was really tight. Ride was really nice. Has michelin pilots.
Bad things, probably needs a power steering pump, master cylinder, altenator. Has an electrical gremlin that constatly blows fuse for tach, blower motor, and windows.
Paid $4,400 for it. I had to drive it straight to a repair shop because its unsafe to drive with bad brakes. I suppose I will have about $6-7k in it before it leaves the mechanic.
What do you think? seemed like a good deal to me.
firefirefire90
Post by firefirefire90 »
oh my, 4.4k for an M5 is always a good deal! :shock:
NZfiver
Post by NZfiver »
Another E28 M5 rescued from oblivion...well done on the purchase and welcome to M5 ownership.
From your description and pictures, the car seems to be a basically sound example, just needs some TLC.
Keep us updated on the restoration work.
rcbmw
Post by rcbmw »
Retro Rust wrote: Mirrors were painted (thats not original is it?)
All E28 M5 examples had body-color side mirrors. Please add this car to the BMW M Registry.
Best,
RCBMW
funfunfer
Post by funfunfer »
Nice find!
I paid $4500 for my M5 to keep it from the "cash for crushers" program. I'm not sure I've discovered ALL of the rust yet!
No matter. Someday it will be presentable again.
Mab1957
Post by Mab1957 »
Welcome to the M5 crew. Get that work done and join us at 5'erFest in Pittsburgh next month.
There's a good group of enthusiasts in GA N.FL. You'll find plenty of help through this board.
Excellent buy Retro! I paid twice what you did (150k mi) but Jeff had done a lot of work to the car. I've had fun doing more myself. I also recently had valve adjustment/throttle synch done and that improved performance. James Muskopf (Paul's Bro) did it for me and inspected chain/guides at the same time. I feel more confident in the s38 now and one low/no clearance valve was found (problem avoided).
Enjoy the experience and join us at the 5'erFest if you can.
gray635
Post by gray635 »
Deal of the month! Good luck with the resto of this M5 - glad to have another one in GA! :banana:
Nice score.
I paid a tad less, but got less too.
Congrats and welcome to the really dark side of E28 ownership.
Retro Rust
Just wanted to give a little update for those who may be interested.
The car had to go to the mechanic imediately after I bought it because I live 4 hours from the PO and the brakes did not work sufficiently enough to drive it home. They determined that it was not the master cylinder, but one caliper that was leaking. I got a set of calipers from a board member and they installed them: brakes now work.
They replaced all fuses: no more fuse popping problem and AC works! :clap:
They removed a filter screen from the power steering system: now that works!
They determined rear subframes bushings and dogbones need to be replaced. Im doing those this weekend, along with swaybar linkages.
So I have just under 6 grand in the car now and it runs and drives with A/C. :banana:
I also took the stock wheels off and am having them sandblasted and epoxy primed. I will be spraying them with Wurth next week.
After the wheels go back on and it can be driven, I plan on having paintless dent removal done to it. Then it should be a pretty straight car.
So hopefully this car will have gone from slipping down into on the way up!
Retro Rust
One other thing: nobody commented on the terrible wooden steering wheel the PO put on. :roll:
I do have the original wheel and it actually looks to be in great condition. Why he would take the original off and put that crap on is beyond me. I also have the orginal gear selector knob. Unfortunately, the PO cut the stitching between the leather boot and the original knob.
rcbmw
Post by rcbmw »
Retro Rust wrote:So hopefully this car will have gone from slipping down into on the way up!
I'm glad to see that you are doing this and keeping the car original/ stock. I'm so tired of seeing M5s totally screwed up and modified. It could not have gone to a better owner.
Best,
RCBMW
Oh yeah, we're interested.
Thanks, it's motivation for some of us.
Mab1957
Post by Mab1957 »
Best,
RCBMW
x2
Good job, stay with it Retro! Hope you can come to 5erFest so I can see it, but if not plan on The Vintage next spring. You'll like the 'stock' M5.
