![Banana :banana:](./images/smilies/banana.gif)
i'm officially back and not pretending to be part of the E28 community with my girlfriends 535is
Well now that you're back from Europe hop on another plane and meet us in Winton-Salem!davintosh wrote:Today: Washed it. Being parked near a flowering crabapple tree this time of year is a messy business.
Yesterday: Swapped out the old bad cheapo distributor rotor for the new good not-so-cheap unit; runs ever so much better now!
Also reinstalled the fuel pump & filter after scrubbing & wirebrushing the bracket for the two and spraying some fresh paint on them. Nobody will be able to see it, but I'll know things are minty fresh down there, and that's what matters.
wkohler wrote:Put some hood shocks on it, put a battery in it and checked to see what worked. Also removed the Alpina wheel locks and loosened all the lug bolts.
I wish. Oh how I wish.rmiddendorf wrote:Well now that you're back from Europe hop on another plane and meet us in Winton-Salem!
HOLY SCHMIDT! That was RUNNING!?davintosh wrote:Yesterday: Swapped out the old bad cheapo distributor rotor for the new good not-so-cheap unit; runs ever so much better now!
Starting and idling, yes, but definitely not drivable. The problem was pretty obvious once I pulled the distributor cap; only wish I'd done that first.C.R. Krieger wrote:HOLY SCHMIDT! That was RUNNING!?davintosh wrote:Yesterday: Swapped out the old bad cheapo distributor rotor for the new good not-so-cheap unit; runs ever so much better now!
Das_Prachtstraße wrote:Got it on the road, N/A. This involved installing and wiring in a thermo fan, filling/bleeding the cooling system, changing the alternator and fiddling with the WAR tune. Drove it about 20km home, and suddenly she turned off. Pulled over, stressed out for a bit, thought it had run out of fuel, filled it up with a jerry can, and still no start. Then noticed on of the damn bellhousing sensors had fallen out.. Loctite those babies!
Now the run in period. Gotta get it registered and roadworthied this week, then make a good few thousand k's to run her in, and then start refitting the turbo stuff. All coming together
