533i not starting HELP!!!
Sam
Post by Sam »
Drove my 1983 533i today to the store. After gettig back in it won't start up. It cranks but seems that its not getting gas???
Checked the "fuel" fuse , cleaned it p and put it back in, still no start.
Can anyone help me with a list of things to check? relays, fuel pump etc...
Thanks
jleezard
Post by jleezard »
Try replacing either your Main Relay or the Fuel Pump Relay. They die for no reason and no warning. I carry a spare with me where ever I go.
pietern
Post by pietern »
You should also check the Fuel Pressure Reg (FPR). make sure its holding the pressure. Use a plier to clamp the hose after the FPR, and have someone start the car.
Sam
Post by Sam »
Are these relays interchangeable with a 87 535i?
e28 gearhead
Post by e28 gearhead »
Okay lets keep this simple
Their are 3 things an engine needs to run:
1 fuel
2 Compression
3 spark
Check spark first its the easiest if you dont have spark check the 2 connectors at the back of the intake on the brace that runs from the intake to the valve cover. These are you crank sensor connectors and they have a tendency to crack and lose connection
m535is
Post by m535is »
Yes the relays are interchangable. It should be BMW's generic 4 prong relay that drives the fuel pump. The main relay should be a 5 prong deal.
Hope this helps,
Sam
Post by Sam »
m535is
Post by m535is »
Yes Sam, the relays are interchangable.
