I have been trying to figure out my cold start system on my 86 535is for the past year without having to buy a bunch of parts only to find out that they did not fix the problem. I am in college and my budget wont support that. But I replaced my csv with a used one that supposedly worked and also my thermo time switch with one that I knew worked. So last night I go to start the car and boom it starts up immediatly in 58 degree weather. Then this morning in 70 degree weather my car takes 10 secs of cranking to fire up...
I don't know what is up. Can someone please help me?
Possible other parts it could be?
Idle control valve
Coolant Temperature switch
Electronics ie bad wiring
fpr
I have also tried switching the ecu and running through the idle faq on the post below
Also i have run through the bently multiple times I am just wondering why it works some times but at other times not.
[Edit by captainmorgan on [TIME]1129565694[/TIME]]
