85 535i 5 speed - NLA
I thought I'd posted this previously, but couldn't find it.
I've had several inquiries, so here's some of the details.
Here's the pic link.
You'll see the cosmetic imperfections.
Current mechanical warts:
Shifter bushings show wear,
upper control arm bushings,
and bad ignition switch (has a push button on the dash beside the column).
The car runs really well.
Not sure of mileage - title says exempt.
Odometer reads 125,652, but it's inoperable.
Rust?
If you'll look in pic 11 and 25 you'll see a small spot at the lower left corner of the windshield opening.
This, other than the surface spots on the hood, pics 3, 4 and 10, is it, as far as I know.
You see the body striping in pic 25.
Some previous owner had some body work done on the front left fender and door, not sure the extent, but this, ugly to me, stripe was all the way around the car.
I began the removal process on the front passenger side and when I got to this area discovered that it had been clear coated over, so it stayed.
Anything else?
"Post reply" in the thread with questions.
As my signature states, $1,500 is the MyE28.com price.
Thanks for looking.
TangerMean
Post by TangerMean »
NOOOO! your supposed to hide this one for me!
GLWTS
TangerMean wrote:NOOOO! your supposed to hide this one for me!
GLWTS
Thanks for the bump, bump.
Jsanders
Post by Jsanders »
Glws, hope you find a good home for it!
It's been a while bump...
Had a little interest bump... :)
NLA as the edited title states.
The change has been noted in my signature.
