Hartge H23 cam specs
I'm going to keep everything as is with the exception of having them add a little lift.
Summary
Detailed
paul burke
Re: Hartge H23 cam specs
Post by paul burke »
Charles Gray wrote:I'm going to keep everything as is with the exception of having them add a little lift.
Summary
Detailed
If this is going to be a regrind you cannot add lift or for that matter reduce the base circle without changing the profile.
I don't know what the final lift is because I can't read the doc. but if their using 1.5 as the rocker ratio its going to be way off.
On the cam pro data sheet it says the duration @ .200 is 112/113 respectively, these numbers should be in the 160 range.
Who is grinding this cam for you? If your in San Diego must be Jerry Cantrell? If you want a brand new chillcast semi finished blank to grind it on I will sell you one then you can retain the proper base circle without welding.
Now that I think about it He should still have a few M20 blanks left over from the '90s. Hopefully he is not still measuring with a BMW foot glued to the bottom of a Chevrolet lifter!! Got a good story about that one but I won't get into it here.
Paul
Paul,
Yes, it is Jerry that's doing the work.
I sent you a PM re your blanks.
Chas.
Devinder
Post by Devinder »
Charles,
Any chance you got the lift curves? I can add them to my M20 cam database.
Devinder
ealinn
Post by ealinn »
Is'nt Jerry Cantrell in a band? Alice In Chains comes to mind but not sure.
Eric
