New Tunerstudio thoughts and opinions.
Scottinva
Post by Scottinva »
Ya i'm not really sure, I hope someone better at tuning then myself chimes in.
George
Post by George »
Hey Peter, will VE Live and the latest addition of TS work well with MS1 or is this just a thing for MS2?
I've been meaning to talk to you about upgrading anyway.
George
Post by George »
Just curious how the VE Live works with the code and tables that all. Remember, MS1 uses smaller tables.
Scottinva
Post by Scottinva »
I wondered this too, and from what I am reading an upgrade from ms1 to ms2 is this.
Automatic Mixture Control: This updates the VE table(s) based on EGO feedback as you drive, tuning the engine automatically.
Since Ve live analyzer is using ego feedback, to correct the fuel mixture, i'm not sure how it would work at all with your setup. I would like to be corrected if i'm wrong, just trying to learn.
Shadow
Post by Shadow »
Ms1 you get to work with 8x8 table instead of a 12x12 (ms2).
Scottinva
Post by Scottinva »
Shadow wrote:Ms1 you get to work with 8x8 table instead of a 12x12 (ms2).
I don't see how smaller tables would affect it, but ms1 does not use ego feedback? I would think thats the main problem. I
Shadow
Post by Shadow »
Ego feedback?
Ok, I see what you're asking. You have edited your post.
You do not need to set authority for ego to have live tune work.
I personally turn that crap off while tuning anyway.
If you don't use ego corrections, live tune won't care if
you keep authority at 0.
Scottinva
Post by Scottinva »
How would it do anything without EGO?
George
Post by George »
Yes, MS1 has ego correction and you set the authority control much like you would with Ms2
Shadow
Post by Shadow »
Idk exactly but just a guess.
Because you're not using it.
You're using VE live tune.
Scottinva
Post by Scottinva »
thesixerkid wrote:Yes, MS1 has ego correction and you set the authority control much like you would with Ms2
Well if this is the case, just try the new tuner studio. I can't even think of a conflict you would encounter when reading the changes from ms1 to ms2, if you have a good saved msq, then you won't hurt anything by giving it a try.
