shrunk hood gasket
Mark in DFW
Mark 88/M5 Houston
I'm guessing you are talking about #19 on the diagram in this URL: http://www.realoem.com/bmw/showparts.do ... g=41&fg=35
If so it presses down on a lip that runs across the back and down both fenders. You may be able to reposition your a bit or check with Brian on availability.
Brian in TN
[QUOTE="Mark 88/M5 Houston"]I'm guessing you are talking about #19 on the diagram in this URL: http://www.realoem.com/bmw/showparts.do ... g=41&fg=35
If so it presses down on a lip that runs across the back and down both fenders. You may be able to reposition your a bit or check with Brian on availability. [/QUOTE]
This part is NLA (no longer available). Checked earlier this year. sigh
