HELP! Installing short shift kit on sheetmetal plate.......
Brian in TN
Post by Brian in TN »
whats the trick to keeping the rod in place on the shifting plate? I know someone here has done this. BTW, the car is an e24 635. Its got the same shifter plate as the e28 does. Thanks guys.
Guest
Post by Guest »
Brian,
I've done a SS kit install on the pre '86 sheet metal shift console.
I don't understand your question, please elaborate.
Rich
shifty
Post by shifty »
You're asking how to keep the shift lever attached to the sheetmetal console? If so, there's a circlip you have to use. Should've come out when you removed the old lever.
derek
Post by derek »
Yes, there is a plastic cup upper washer, spring and clip. Cut the upper washer to get it around the shift ball. Don't worry as it's ultimatly held in by the circlip.
Brian in TN
[QUOTE="derek"]Yes, there is a plastic cup upper washer, spring and clip. Cut the upper washer to get it around the shift ball. Don't worry as it's ultimatly held in by the circlip.[/QUOTE]
I think you may have solved the problem Derek. Thanks dood! We will see what happens.
