Removed 1.0 and then pics of 1.3 installed. I capped off the purge and the charcoal canister going to the bellows after i took the pic but it runs really well. I finished but ran out of time to go to get vacuum line.
Got rid of the thermotime switch, reference sensors (2), and that pesky cold start valve.
I got a DINAN chip im going to install tomorrow to see what happens.
Jbort modified a super eta wiring harness for me so i can do my swap, many thanks Jay, my project wouldnt have worked without ya
Had to install my m30b35 secondary ignition wires, crank trigger and bracket from the m30b35, the m30b35 harmonic balancer, super eta coolant temp and sender sensors, super eta harness, m30b35 small case starter (half the weight of the large case) and super eta oxygen sensor. took me about 5 mins to remove the starter, its pretty easy.
Its much smoother than motronic 1.0 and will see how it affects my fuel economy with a 3.73 LSD
