Right now we have the default board appearance called "Plain Jane" , which is simple and mostly white.
You can also select "Orange" which is a bit more colorful, or "blue" which is dark blue.
To do this go to User Cp / Board Options / Skins.
The board will remember your selection and appear the same way the next time you visit.
Of course you can change your preferences at any time.
Board Colors / Personalization
Craig -535i- Seattle
Bryan in NC
Tim in N FL
Hi William,
Is there anyway for the menu-driven HTML tags to be used more easily? For example, if I highlight a section of text and click the "italics" button, in vBulletin (and whatever is used on www.rennlist.com ) the tags drop into the appropriate location. With the CuteCast interface the tags are dropped in at the bottom of the message being typed. Please advise....and thank you!
Tim
Tim
