88 535is fuel & temp gauge and windows don't work
My fuel and temp gauge had been working intermittenly until yesterday when they stopped altogether. I'd start the car and no fuel and temp then when I started moving they'd come on and the test light blinks until I hit the brakes, then all was well. Yesterday they never came on at all in 3 seperate trips. Also when they don't work the windows don't work either. No fuses blown. Is there 1 relay that controls all these items? Any ideas? Thanks
Bimmerguy2002
- Beamter
I don't recall offhand which fuses control these, but I'd definitely check all grounds under the hood ie; motor>chassis ground straps, alternator accessory lead, & battery accessory leads.
Aside from that check here http://wedophones.com/BMWManualsLead.htm.
for an ETM to assist you on this.
- Beamter
Re: fixed
Gotta love it!FB535M635 wrote:crappy 8a fuse, wasn't visibly blown but doesn't work either. Issue resolved, I should probably not assume the worst every time I have an issue. Thanks
