The 1st image may be the ABS sensor connector???
2nd is the interior temp sensor vacuum line. Connects to a nipple under the manifold. Feel around, hard to miss.
kojo96 wrote: Mar 09, 2025 7:44 PM
And that black part is supposed to be a flow restrictor to minimize the vacuum leak, although IIRC they were cloth covered. So, if it is a flow restrictor, keep it, if it's not, it's just a size adapter between the semi clear plastic and the vacuum port on the bottom of the intake, in which case you'll need it or something anyway.
