And so it starts, Maeve
gwb72tii
Re: And so it starts, Maeve
Post by gwb72tii »
It was part of my car when I bought it. You can find it on Realoem ,p/n 31112225218. You can buy it from ECS tuning.
kojo96
Post by kojo96 »
gwb72tii wrote: Jan 05, 2025 12:34 AM It was part of my car when I bought it. You can find it on Realoem ,p/n 31112225218. You can buy it from ECS tuning.
gwb72tii
Post by gwb72tii »
Installed the driveline today. It's one of those things that until you figure out the steps to get it into place, it seems to not want to fit. Next time it will be about a 10 minute job, today it took me better part of 30 minutes.
gwb72tii
Post by gwb72tii »
I was able to replace the rubber "back door to B pillar" connection for door lock and window electronics. I'm too embarrassed to show the details on this side as I completed went full retard before I solved the mystery on what to do.
And thank you to those that replied about an under rear seat sub woofer. My last e30 had a forward facing 10" sub that fired through the back seat from the trunk and it sounded great, so I picked up this 8" compact sub and will see how it goes. Part of the issue right now is time and effort, I want to get Maeve on the road. The e30 has a cutout panel behind the rear arm rest making it easy to provide a path for the sub to fire through, the e28 does not. I'll bet the under the rear seat sub sounds ok.
gwb72tii
Post by gwb72tii »
Big thanks to harrypalmer for sending pics on the heater box flap actuator orientation. This was the last obstacle to getting the heater/AC boxes reinstalled.
Blue Shadow
Post by Blue Shadow »
The US cars did not have that hole in the back firewall, but some € cars could have been so equipped:
RealOEM.com - Online BMW Parts Catalog
I use a known M535i VIN when I need to look up € parts.  Expect it was available for all the models
Blue Shadow
Putting the sub in the trunk can lead to a lot less trunk space if you go with a pair of 10s and amps.
Blue Shadow
Oops, off topic but, Hot Damn, it works. I can finally post pictures.  Haven't since photofuckit tried to extort us for hosting.  They gotta be the worst, watermarking through the middle half of the pictures.
Blue Shadow" wrote: Jan 27, 2025 9:32 PM Oops, off topic but, Hot Damn, it works. I can finally post pictures.  Haven't since photofuckit tried to extort us for hosting.  They gotta be the worst, watermarking through the middle half of the pictures.
gwb72tii
Post by gwb72tii »
holy sh*t, you could bounce your car across the parking lot with that setup
yes, and thanks tig. I just clicked on things until it worked, coincidently Imgur is not working for me any longer. you do any off-road in your FJ? I'm looking for a truck/SUV type vehicle that I can take off road in search of trout
Blue Shadow
gwb72tii wrote: Jan 27, 2025 11:04 PM
It is slightly different right now, using a Sony XEC-1000 crossover meaning the amps are rotated to make room and since it isn’t 100%, Come on, I’ve had that rig since 1988 in the ride. I’m gonna pull the board, add another amp for the woofers and maybe refresh those PQ-10s. Need to talk to my a/d/s/ guy about the need. That will double the power to the corners (aDs 300i and 320i) and give the woofer some more, too.  But it’s an Alpine amp for the woofers going in.   Loud but sounds good. Not looking to rattle any sheet metal.
But trying to pm a pic and no luck in a quick try so I have to actually read tig’s post on how to with pictures. I’ll get there, but a damn fine upgrade already, being a fresh forum with pictures.
gwb72tii
Post by gwb72tii »
Ta da! Getting the servo motor mounted correctly has been on my mind for a long time.
gwb72tii
Post by gwb72tii »
A bit more progress. Replaced the "S" shaped raceway for wires that travel to the inside of the door. the ones that came with my car from Mesa AZ were dried out and in pieces. I bought two different terminal removal tools, both broke, so I had to cut the wires and then solder them back together.
/images/uploads/32587/2b31e8eb5d8d6227_original.jpeg
Blue Shadow wrote: Jan 27, 2025 9:32 PM Oops, off topic but, Hot Damn, it works. I can finally post pictures.  Haven't since photofuckit tried to extort us for hosting.  They gotta be the worst, watermarking through the middle half of the pictures.
Often I've found you can right click, open in a new tab and the watermark is gone. :shock: Kind of a moot point but it can come in handy on other sites too.
gwb72tii
Post by gwb72tii »
Out with the old, in with the new. This may have been something unnecessary, but something I've done on every older car I've owned, new brakes. The M/C is OEM 535i spec as others have opined a larger M/C is not needed or wanted (thanks Shawn D.)
gwb72tii
Post by gwb72tii »
I'm starting to address the trim. One piece is the hat shelf behind the rear seats. As you might expect, it has completely faded from the hot/sunny AZ climate. This is what it looked like about an hour ago:
This is what it looks like now:
The color is a shade darker that my reupholstered leather rear seat, but close enough I think. The speakers are faded as well but I'm not sure they need to be the same shade as the hat shelf. Even if it's not quite the same as from when it was brand new, it looks better.
gwb72tii
Post by gwb72tii »
And this came in the mail today from eBay. It's been a good day. Plus its 63 degrees in the Pacific Northwest on Feb 27th!
gwb72tii
Post by gwb72tii »
Working on fun things today, rear and front speakers. The PO of Maeve had installed replacement Pioneer speakers in the rear. Their condition was marginal due to AZ heat, so the need to replace the Pioneers. Luckily I have been through this before with the last e30 I owned. The PO however removed the BMW tweeter so its mounting bracket was missing. I found Dayton Audio tweeters on Parts Express in a round plastic mount that I cut away to fit the tweeter opening. The replacement mid-woofer is stock BMW. The tweeter is ridiculously good for its price, and the BMW mid-woofer is from an e39. Bigger magnet, better sound than stock e28.
I can tell you this combo is terrific for hi-fidelity sound. I will be running a separate amplifier as any head unit amp is less than optimal. Once you've heard a car audio system with a correctly tuned amp you'll never rely on any head unit's amplifier for good sound. Night and day. You can basically tune out distortion.
Pioneer crossovers from the PO
gwb72tii
Post by gwb72tii »
On to the sail tweeters. Same thing, old tweeters were dried out. And same thing, Dayton tweeters for the win. These tweeters are sweet.
You pry our the old tweeters carefully with a small screwdriver, then hot glue the Daytons in.
The crossover driving the tweeters is part of the side panel speakers located near your knees.
gwb72tii
Post by gwb72tii »
Making progress on small things, like vacuum lines, speakers etc. No pics but making sure small things hat can cause larger problems are caught  now vs later.
gwb72tii
Post by gwb72tii »
When I started the renovation of Maeve, my intent was to get her back on the road with a refreshed suspension, new interior and a much better motor. Smaller things I could take care of as I used the car as a DD. So here I am 2 years later (sigh.....) and little things keep popping up that I can't ignore. And to fix little things, most often I need OEM parts of some sort that take 7 to 10 days to arrive.
The lated is when putting the doors back together after cleaning a lubing the window mechanisms, I find the door latches are cracked, presumably from the AZ heat where Maeve has been for the last 30+ years. And then the little plastic bushings that the various door lock rods go thru. I do not want to remove the door panels and locks to fix them later, and a huge pet peeve is a car that rattles from little things. So there's 2 more 10 day delays, and it all adds up. Here is the lates culprit:
The good news is I'm very much in the end game to getting Maeve on the road, hopefully haha.
DavidE9
Post by DavidE9 »
Im running those tweeters too. Cant beat the price for the sound. Look into Dayton mid-base speakers too. If I had to do it all over again, Id put their 4" mid base in the front kick and call it a day.
MLastovo
Post by MLastovo »
gwb72tii wrote: Mar 15, 2025 3:20 PM ... part of the side panel speakers located near your knees.
While you are in there, I highly recommend installing number 22 in the following link.
https://realoem.com/bmw/enUS/showparts?id=4224-USA-03-1985-E28-BMW-524td&diagId=65_0402
Why were they only offered stateside in the td? I have no idea but they are available and really help the sound of the kick panel speaker(s).
D.
John in VA
Post by John in VA »
D.
Foam ones are also available from hifi vendors.
MLastovo
Post by MLastovo »
John in VA" wrote: Apr 03, 2025 3:43 PM
D.
The OEM offerings are foam as well.
r/
D.
gwb72tii
Post by gwb72tii »
Some progress today although I'm running into an early spring and the resulting gardening work to support my wife and her garden. Plus having to mow with our tractor to keep the grasses under control.
So today I cleaned and lubed both rear lock assemblies. How do they get so effin' grungy? Plus the old grease is now basically caked on wax. Replaced the missing small plastic grommets that locate the various rods controlling the locks. Mine were completely absent and would result in rattles inside the doors, a pet peeve of mine.
Then I finally located the rear headrest brackets and installed them to the rear bulkhead. My car came with rear headrests but not the brackets. If you're paying attention I will have a set of brackets to sell/give to someone.
First crop of asparagus. It's stunning how much better fresh cut asparagus tastes vs store bought. Made a quiche with some with gruyere cheese and bacon.
gwb72tii
Post by gwb72tii »
I've been stumped somewhat on the exhaust assembly, and thanks to help from ahab and others I've got it figured out.
viewtopic.php?t=162781
Now that the wife's drip irrigation to-do-list-for-me is done, I'm back to working on Maeve. I'll be installing the exhaust tomorrow afternoon, and then perhaps next weekend will be start-the-motor-for-the-first-time weekend. Maeve has 2 year old gas in the gas tank so I'll need to drain it and fill it partially with new gas. This will be the first motor I've started from new that I haven't rebuilt myself, so no second thoughts or doubts about whether I actually torqued the rod nuts or other such things. Pretty exciting!
gwb72tii
Post by gwb72tii »
I am a terrible at estimating how long things take to get back together. I'm nowhere near getting Maeve started. I keep running into little things that need to be fixed that need ordering from various parts suppliers that take time to arrive. I am however making progress. Most of the intake system is now in place, all the way to the air filter. But frustrating.
My next major job will be reinstalling the dash. It's been so long from when I removed the dash for refinishing, tearing my right shoulder apart, surgery and recovery, that I've forgotten where everything goes. I need to install the heater box and A/C. I've completely rebuilt both, but I'd sure like to be able to bench test both prior to install. Oh well, fingers crossed that all is in order. Then installing the sunroof assembly and headliner. Fortunately I've installed more than one headliner in my 2002tii so I pretty much know what to do.
The next job after that is to drain the fuel tank that has 2 year old gas in it. Plus replace some of the in tank tubing to the in tank fuel pump that tig and others have done.
Pics tomorrow.
gwb72tii
Post by gwb72tii »
It's starting to look like a motor
