WYSIWYG Editor Discussions
I am running a test of a potential new MyE28 Post Editor. It may or may not work well. GIve it a try. If it works well and people like it we'll leave it enabled. Otherwise we'll keep working.
Note: You can't use the editor to direclty enter Image Links (img tag).
  1. Lists
  2. Work
  3. As
  4. Expected
    1. Even indented.
    2. Like this
And, of course, bullets:
  • Bang
    • Banger
  • Bang
YouTube vids work inline!
:cry:
Whoa.
A horizontal separator line is above this sentence.
Below is a table:
CarSpeed
525Slow
535Faster
IMAGES ARE WORKING!!! (Just don't drag & drop yet).
like this:
This is a test.
This is a centered test.
This is a right-aligned test.
This text is justified. Bacon ipsum dolor amet beef salami picanha burgdoggen tail ball tip frankfurter tri-tip, shankle tongue capicola corned beef. Pork chop chuck flank salami. Shank chuck pork chop, meatloaf cupim cow leberkas bresaola turkey t-bone prosciutto ham hock doner ground round. Buffalo porchetta meatloaf pastrami alcatra. Swine chislic alcatra shoulder flank venison kielbasa salami doner corned beef meatloaf shankle. Picanha short loin ribeye meatloaf swine pork loin.
Re: TESTING - New WYSIWYG Post Editor
Image linking is now working. Use the Image button:
What is NOT working is dragging & dropping an image.
Any feedback?
How are people finding the new editor experience?
Weird.  After all these years I've gotten pretty comfortable with the bracketing, especially where interjecting a bunch of different comments after a block of text, like answer one question, then the quoted text, then answer the next.  I've done that half a dozen times in a single post before.  I'm not sure how to do that now, although I haven't really looked.
I'm so used to it I'll use it on other sites where it doesn't show that formatting working, but it does.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
When working with a quoted post, I've had it add extra line breaks and justify code. Also more than once, after hitting preview, the post appears correct up above, but everything I had written was gone in the WYSIWYG editing box.
If you really hate the new WYSIWYG editor, I've just implemented a feature that lets you turn it off.
Got to your User Control Panel (UCP): ucp.php?i=ucp_profile&mode=profile_info
And check the checkbox, then hit Submit:
For now, I ask you to NOT DO THIS. Continue to use it and provide feedback. Thanks.
Mike W." wrote: Jan 03, 2025 2:15 AM Weird.  After all these years I've gotten pretty comfortable with the bracketing, especially where interjecting a bunch of different comments after a block of text, like answer one
Hi!
Here's how to do it:
Justin_FL wrote: Jan 03, 2025 2:04 PM When working with a quoted post, I've had it add extra line breaks and justify code. Also more than once, after hitting preview, the post appears correct up above, but everything I had written was gone in the WYSIWYG editing box.
I'll try to rerpo & debug this. Thanks for the report.
Note the Smilies toolbar button now inserts Emojies not the old smilies.
Smilies: 💩?
Emojis: 👍?
Is this an upgrade or downgrade?
szacsi72
Post by szacsi72 »
tig wrote: Jan 01, 2025 7:38 PM I am running a test of a potential new MyE28 Post Editor. It may or may not work well. GIve it a try. If it works well and people like it we'll leave it enabled. Otherwise we'll keep working.
  1. Lists
  2. Work
  3. As
  4. Expected
    1. Even indented.
    2. Like this
  • Bang
    • Banger
  • Bang
:cry:
Whoa.
Below is a table:
CarSpeed
525Slow
535Faster
like this:
This is a test.
Oh yeah.
The table option is AWESOME.
I'll update the M30 build specs post later with it!
szacsi72
Post by szacsi72 »
Well here's the first bug I found:
Believe me, my message is NOT 165997 characters long, haha
szacsi72
Post by szacsi72 »
Oh, okey, now I see.
So I tried the new picture function, CTRL C - CTRL V doesn't seem to work.
szacsi72
Post by szacsi72 »
The second bug I found is, that when I tried to edit an older post on my thread, the editor only loads up roughly 30% of the post - the rest is just gone, and I cannot edit it?
szacsi72 wrote: Jan 09, 2025 12:51 PM The second bug I found is, that when I tried to edit an older post on my thread, the editor only loads up roughly 30% of the post - the rest is just gone, and I cannot edit it?
Which post?
szacsi72
Post by szacsi72 »
tig wrote: Jan 10, 2025 9:50 AM
Which post?
Multiple posts, but for example, the first post on my build thread does it.
szacsi72 wrote: Jan 10, 2025 3:35 PM
Which post?
Yep. I can reproduce it.
I recommend you turn off the wysiwyg mode for now as I debug. You can do it in your UCP.
tig wrote: Jan 10, 2025 7:14 PM
@szacsi72,
Your post had an extra "[/i]" in it. This was causing the editor to fail.
I will continue to try to see if I can make the editor more robust, but in the meantime, I manually edited your post to remove that extra markup and the wysiwyg editor is now working fine on it.
If you have other posts where this happens, please:
1) Turn off WYSIWYG in your UCP.
2) Edit the post to find/fix any invalid markup (e.g. unbalanced tags).
3) Turn WYSIWYG back on.
4) Verify that the editor does the right thing.
For anywhere you still can't get it to work, please post a link to that post here in this thread.
I've added some code that at least shows an error message when a post has malformed BBCode in it and you try to edit it.
Like if you try to quote the message above:
I'll continue to make this better as I have time, but for now this should be super helpful. No?
szacsi72
Post by szacsi72 »
Looks good to me!
I've added a checkbox to the posting page that lets users switch between the built-in Source editor and the WYSIWYG editor.
The WYSIWYG editor is enabled by default on a per-user basis.
This can be changed in the User Control Panel. If this is turned off the default will be to use the Source editor.
On a per-post basis, users can override how they have UCP set with the checkbox at the bottom of the editor.
gruntled
Re: WYSIWYG Editor Discussions
Post by gruntled »
Hi all.
I've got Photo Upload integration working with the WYSIWYG editor.
Just drag/drop photos onto the editor to upload.
I know this is isn't exactly the discussion topic, but it does regard the new site: Is there anyway to load in the old emoji's we had in the previous version?  There was many that were unique to a car forum and just great overall. Frankly the massive list currently loaded is mostly useless.
Ahhh, I'm finding the whole WYSIGYG editor to be more trouble than it's worth. I still can't get any .gif's to upload via drag & drop
vinceg101 wrote: Apr 22, 2025 11:38 AM Ahhh, I'm finding the whole WYSIGYG editor to be more trouble than it's worth. I still can't get any .gif's to upload via drag & drop
Email me the GIF you are trying to upload. There are some limitations based on how big the GIF is.
Oh, and regarding GIFs there should be no diff between the two editors.
