Holy Grail Labs - Blade Fuse Upgrade Kits
325racer
Post by 325racer »
Good idea, will probably try that later in the week or next weekend. If you see anything that makes sense, please let me know.
Galahad
Post by Galahad »
325racer wrote: Sep 03, 2023 6:49 PM Good idea, will probably try that later in the week or next weekend. If you see anything that makes sense, please let me know.
I looked at the ETMs and the schaltplane and I am stumped. Get any testing done? It could also be helpful to pull the lighting relays and see what changes
Galahad
Post by Galahad »
Happy new year!
I'm looking for people to test two prototypes, both for E10 / 02 cars.
one is fuse box part # 61131352373 (12 fuse 03/71 to 08/73, has sideways blades)
the other is part # 61138460100 (6 fuse 03/66 to 04/72)
Testers would need to get me info within a month and will receive a free production unit once I have made any necessary changes.
Reach out to the HGL support email (support@[website]) if you're interested!
pdor123
Post by pdor123 »
Hi, I have a US m5 with the euro headlights converted by a prior owner. After installing the HG fuse panel I incorrectly bridged fuses 7 & 8 so fuse 8 (left high beam) blew.
Another glitch that could be related: I depinned connector 85 from the high beam relay but destroyed it. After repairing it, I replaced fuse 8 and removed the bridge at fuses 7 & 8 and inserted 15 amp fuse in fuse 7 per troubleshooting FAQ.
When low beams are on, both sides work. If high beams are on, only the right high and low beams work, and neither the left high and low beams work.
The center red lens of the tail lights are illuminated when the battery is connected even without the key in the ignition. Removing fuse 9 temporarily resolves the issue. The lights were modified previously to add an additional bulb in the extra space. I did not notice this issue until after troubleshooting the headlights.
I noticed a few differences in the photos in the HG flicker account and the ones I took. Ex: The gray/white wire is on an adjacent tab of the same colored cardboard index. I initially put the connectors back according to my photos and then according to the flicker account, then in various combinations of both. I still have issues with the headlights and the tail lights. Please help. Thanks in advance. Patrick
MisterFixit
Post by MisterFixit »
pdor123 wrote: Jan 24, 2024 4:21 PM Hi, I have a US m5 with the euro headlights converted by a prior owner. ... Please help. Thanks in advance. Patrick
Patrick, this sounds like another thread is in order, at least a private consult. I have done several headlight conversions for Euro operation (2002 and E28 and E30) that lights high and low filaments simultaneously... safely.
I have also been upgrading rear lighting for decades. I believe the HGL fusebox upgrade shouldn't be the source of any issues there... and can help you troubleshoot the weirdities in back as well as add more lighting safely for higher output, greater reliability, and a larger visual profile. Shoot me a PM and we'll talk.
I am curious about your statement about 'destroying' the relay 85 pins...
Andy
Galahad
Post by Galahad »
Hi Patrick, sorry to hear about your issue. Email would probably be easier, I suspect you've swapped a couple wires around.
-Galahad
MisterFixit
Galahad wrote: Jan 24, 2024 7:15 PM Hi Patrick, sorry to hear about your issue. Email would probably be easier, I suspect you've swapped a couple wires around.
-Galahad
+1
pdor123
Post by pdor123 »
MisterFixit wrote: Jan 24, 2024 6:42 PM
Andy
I inadvertantly destroyed the connector that relay pin 85 plugs into.
pdor123
Post by pdor123 »
-Galahad
Please advise how to contact you via email. I'm new here and only see a link to your HGL site. Thanks, Patrick
Galahad
Post by Galahad »
pdor123 wrote: Jan 24, 2024 7:38 PM
-Galahad
It's support(at)[HGL site]
MisterFixit
pdor123 wrote: Jan 24, 2024 7:36 PM I inadvertently destroyed the connector that relay pin 85 plugs into.
Oh, I see. You say you repaired it, but if you need more of the locking connector (female terminals), I have bags of them. They are new Hella parts.
Let me know if you want anything regarding rear light repairs, upgrades, etc.
Galahad
Post by Galahad »
Got Patrick's car working; US cars that were converted to euro front lighting at the headlight plugs need the bridge fuse since the fuse box wiring hasn't changed.
That edge case hadn't been addressed anywhere, I updated the FAQ to clarify.
pdor123
Post by pdor123 »
Thanks for the exceptional support.
Galahad
Post by Galahad »
Hi everybody!
Holy Grail Labs is excited to announce a new product line of blade-style fuse boxes for the BMW 02 and E3 series cars!
The new products are full fuse box replacements, including a new frame, gasket, OEM cover, and fuses. These fuse boxes include Holy Grail Labs' time-tested LED indicator circuitry. Installation is as simple as removing the old fuse box and plugging in the new unit.
We are providing both 12-fuse variants, covering 3/71-8/73 cars and 8/73-7/77 cars. The latter box also fits BMW E3 models built 9/73-2/77.
A kit to replace the 6-fuse variant used in 3/66-4/72 cars has been designed, if you are interested in testing this contact us at support (at) holygraillabs (dot) com.
MSRP is 319 USD, available now! Visit our store page to place your order today.
I've included photos of a prototype below, so you can expect minor differences in the production version.
Shawn D.
Post by Shawn D. »
Galahad wrote: Feb 04, 2024 10:31 PM Holy Grail Labs is excited to announce a new product line of blade-style fuse boxes for the BMW 02 and E3 series cars!
Sweet! Y'all are really doing some great work supporting our vehicles!
Galahad
Post by Galahad »
Shawn D. wrote: Feb 06, 2024 1:28 PM
Thanks! got a couple more coming down the pipe too
Galahad
Post by Galahad »
Hi everybody!
All the new units - E3, E9, and both 12 fuse 2002 variants - are in stock! We're happy to have been able to reduce the price to 319 USD for the new models and are looking forward to getting these into peoples hands.
As always reach out if you have any questions.
2002 Fuse Box
E9 Fuse Box
E3 Fuse Box
jacobthegoat
Post by jacobthegoat »
Quick question -
Just did the retrofit blade fuse project yesterday. Everything works properly except fuse #10
When I use my left blinker, the front bumper marker doesn’t illuminate, and it throws a check light on my check panel for rear license plate lights and rear lights, although they function just fine. Only the front turn signal marker doesn’t operate. I checked the bulb and also the wiring. Bulb is good. Wiring I’ve checked twice, everything is back where it was originally.
Also the LED on fuse 10 blinks on and off with the rhythm of the turn signal
Galahad
Post by Galahad »
jacobthegoat wrote: Jun 21, 2024 2:26 PM Quick question -
Fuse 11 is for the blinkers, not fuse 10 (various marker lights). Something got plugged in wrong, having the LED blink on and off is a new one. Can you email us (or post here) some pictures of the wiring inside your fuse box? I'm looking at the ETM and it's not immediately obvious what could cause that.
Galahad
Post by Galahad »
Hi everybody!
At long last we have mini boxes in stock and available on the website!
Price is 28 USD by itself, 21 if purchased with an E28 blade fuse upgrade kit. Kit includes a new mini box, a new bracket, fuses, and crimp connectors.
Available Here
Ordered.
jacobthegoat
Galahad wrote: Jun 21, 2024 5:19 PM
Turns out everything was wired correctly, the bulbs tested good, but after replacing the turn signal bulbs with new ones, everything works properly.
Dang I was just a few weeks late to order the spare fuse box! Price is good for those, I spent $50 on a replacement bullet style aux fuse box just a few weeks ago. Nice work.
Galahad
Post by Galahad »
jacobthegoat wrote: Jun 28, 2024 8:07 AM Turns out everything was wired correctly, the bulbs tested good, but after replacing the turn signal bulbs with new ones, everything works properly.
Weird solution but glad it's resolved!
Thanks for the positive comments
Galahad
Post by Galahad »
We have color cards for E28s now! They are a huge help when installing fuse box kits, I was able to do 90% of a box without needing to look at photos. Euro on one side, US on the other. Made out of temperature resistant materials, and colors were picked to match how the wire colors usually fade.
Currently these are for E28s only, we're looking into the other models that the E28 kit works with but there's a significant number of variations.
16 USD, available here if you're looking for some extra help on an upcoming kit install.
Prybar
Post by Prybar »
Hello
I just completed the installation of the blade fuse upgrade in my '79 e12.  Almost everything is good, one issue that I can't seem to figure out.
When the high beams are engaged, the right side keeps popping the fuse.
Low beams work properly, Left high beam works properly, but the right burns a fuse every time.
I am using 7.5 amp fuses for the beams and a 15amp fuse for the "USA cars fuse" spot.
I tried a 10amp for the right side, that pops too.
I have checked and rechecked the wiring and as far as I can tell, everything is where and as it should be.
Any suggestions on how to approach this?
Many Thanks
Luke
Galahad
Post by Galahad »
Prybar wrote: Apr 06, 2025 3:01 PM Hello
Many Thanks
Luke
Check the resistance of your high beams, and post (or email support) a photo of the wiring inside the box for those two fuses. Which fuse # is the one popping? Do the left ones light properly?
Prybar
Post by Prybar »
F7 is the one popping.  The left side works as it should. It is only the right high beam that has an issue.
May you explain "check the resistance of the high beams"?  would I do that from the fuse box? or check the bulb itself?
I will email a photo to support.
Prybar
Post by Prybar »
Posting here in case this is helpful to anyone in the future.
Here are the photos of the headlight side ( F7 and F8 ) area of the panel from the underside.
sam196370
Post by sam196370 »
I installed this in my 535i, lights much brighter and better electronics all around. One thing is the ground wire connection blade is very fragile, I broke mine and now the check lights don't work. Not sure if I should send back or attempt to re-solder.
Galahad
Post by Galahad »
sam196370 wrote: Apr 11, 2025 9:38 AM I installed this in my 535i, lights much brighter and better electronics all around. One thing is the ground wire connection blade is very fragile, I broke mine and now the check lights don't work. Not sure if I should send back or attempt to re-solder.
Sorry about that - we'd be happy to exchange or otherwise help out, send an email to support.
