I've got a couple left, shoot me a PM.
Good Morning,szacsi72 wrote: Jan 09, 2023 8:43 AM Hi Guys,
The adapter plate will be $15 a piece; a kit, including the adapter plate and a brand new FEBI unit will be $115.
Please send me a PM if you want one!
David
I have not tested them, but I suppose the bracket should work, as the bolt pattern is the same due to the master cylinder.
Robert- it is my understanding that the heater valve opens and closes to admit hot water (coolant) into the heater core, so after heating for a while, the core is full of Hot Coolant.robertodonnell wrote: Dec 02, 2023 1:29 AM Hi guys,
Can I ask everyone that's done this conversion, does the heater turn completely off when you turn the knob to cold after its been on heat? I rebuilt an OE valve, and it works fine on the bench, but still bleeds heat into the cabin if I've turned the heat up for a while. Thinking I was smart, I bought an Audi valve and fitted it today, and the brand new valve does the same thing!
Cheers,
Robert
Well, that's different. you likely have a torn diaphragm or other defect in the valve - or a connector / electrical issue.robertodonnell wrote: Dec 03, 2023 1:32 AM It still should cool down within a reasonable time frame, once the valve is shut and the supply of hot water is stopped. In my E34, and my once owned E46, it will return to full cold in a not too long a time...within the time it takes for you to hod your hand there and feel the heat drop off...this stays full hot until the engine cools down!
gaza01 wrote: Jan 06, 2025 11:47 AM Where people are fabricating the bracket for the HCV, what is the diameter of the holes for the rubber plugs?
szacsi72 wrote: Jan 07, 2025 9:53 AMgaza01 wrote: Jan 06, 2025 11:47 AM Where people are fabricating the bracket for the HCV, what is the diameter of the holes for the rubber plugs?Gaza,
I'm not fabricating, but I'm offering the brackets and kits.
However, since I don't do it for profit, I'll happily share. The holes are exactly 25.0mm and the rubber plugs fit very well.
Regards
Dave
4DSC wrote: Apr 02, 2025 12:50 AM About to start this conversion and wanted to confirm something about the wiring. When putting together a connector, does the ordering of the pins matter, or is there no such thing as connecting the heater valve "backwards"? Don't want to accidentally damage a new valve.
Looking at an installed upright e46 valve from the driver's fender, the left pin should be connected to positive (GN/WT wire going into original e28 connector per e28 ETM) and the right to ground (BR/GN per e28 ETM)?
demetk wrote: Dec 11, 2016 11:03 AM If you don't mind, I'm adding to this thread instead of making a new one.
Here's an e46 valve installed on an M6 with a sheet metal bracket that you can make in like 30 minutes.
The bracket,
Removed the rubber grommets and tapped the holes with an m6 tap,
Attached the bracket with some short m6 bolts,
For the wiring I simply soldered an existing connector I had handy to the valve and epoxied it in place,
Hose layout. Sharkbite 1" barbed fitting was used to connect 2 pieces of hose together,
Just clears the intake manifold on the M6. It should be a lot more room on the M30,
Hello demetk! Jeff here from Warren CT. I am replacing an original heater valve with a new e46 one like yours. I have an M5. I am a bit confused about the plumbing. Can you confirm that the bottom nipple on the e46 valve (it has an arrow pointing into the valve), goes to the back of the block. And the top nipple is connected to the heater core? Or do I have this backwards for this heater valve?
many thanks, Jeff
milarsky wrote: Jun 07, 2025 11:21 PM Hello demetk!
many thanks, Jeff
