Vlad: The Zinno '87 535is
Re: Vlad: The Zinno '87 535is
Here's the build thread. It just needs to be moved to "Eye Candy" viewtopic.php?f=2&t=159331
I just did two years' worth of catching up. After seeing your work on the wiring harness, I've decided you need to come and help me get my car running again. Please?
Also, where were you when I was looking for calendar fodder a month ago? Or a better question is, why did I not subscribe to this thread a long, long time ago? I've fixed that anyway; the calendar is already done.
Such a cool shot...
Such a cool shot...
Over the last couple weeks I’ve read through your thread, as well as your b35 build thread. Love the detail you put into the car, but especially into the threads. It is truly a resource for the community. Looking forward to your standalone solution!
Warren
Warren
Tee-hee. Glad I could entertain!CanadianMiniFan wrote: Jun 20, 2023 3:37 PM Over the last couple weeks I’ve read through your thread, as well as your b35 build thread. Love the detail you put into the car, but especially into the threads. It is truly a resource for the community. Looking forward to your standalone solution!
Warren
Here's some gratuitous shots of Vlad testing my new 2-post lift at Gruntled HQ.
Full Garage thread here: https://www.garagejournal.com/forum/thr ... led.91146/
Nice. Hard to imagine a prettier e28 car. Big fan of the Venetian blue 911, too!
Proper garage you have there!
Yup. Gruntled HQ is coming together.
More here: https://www.garagejournal.com/forum/thr ... led.91146/
Only took me like 8 years, but I finally connected the driver's seat heat on the E34 sport seats.
Because there is no readily available on-in-start-or-run power source near the seat, and because I don't want to pull the carpet/kick panel to pull a wire, it is currently always hot. But i wired it with a plug that will make it easy to put an in-line power off delay like this one (ordered):
https://www.amazon.com/gp/product/B01HNDOCKK
This is needed because leaving the seat heater on will quickly drain the battery.
I also fixed a slight twist in the seat.
I'll get to the passenger seat in several more years. Maybe.
Charlie, are those M5 or 95 M Sport or "just" e34 sport seats?
Could you educate us as to the stitching differences due to your extensive knowledge of the E34 spot seats? I have an option for a pair of blacks locally from a friend.
They are a bastardized set from 3 different sets of E34 Sport Seats. Not sure what cars they originally came from. Sorry.Spen wrote: Sep 28, 2023 11:25 PM Charlie, are those M5 or 95 M Sport or "just" e34 sport seats?
The seat back bolsters are ///M stitched.
The seat bottom is not ///M stitched.
more pics: viewtopic.php?f=7&t=115049&p=1204070&hi ... s#p12040701st 5er wrote: Sep 29, 2023 6:50 PM The seat back bolsters are ///M stitched.
Found my thread where I built these: viewtopic.php?t=120566
Looks like I used an ///M stitched bolster only on the driver's left side.
Nice car
Uh oh...
Both the input and output shaft bearings leak anyway...
Now the list of things I need to do to make this car even more perfect expands:
- Swap out clearly failing 260/6 and put in either the 265/6 or 260/6 I have laying around. Current vote is the 265/6 but until I verify that the two spares are actually good... I believe it shouldn't be hard to put the 265/6 in and retain my Autosolutions shifter.
- Reseal the engine (timing chain covers, rear main seal).
- Check the status of the oil pump (I've long been nervous that I did something wrong rebuilding it).
- Install the M5 steering box I have lying around
- Nuke the WAR chip/MAF and replace with something better (I recently ordered one of these for Maytag... if it's any good I'll go that direction on Vlad too: https://www.classicdaily.net/collection ... d-play-ecu)
- Upgrade sway bars.
- Replace dogbones. The rest of the suspension looks good still.
- Nuke PO's lame headlight relays and re-do headlight wiring circuit
More research is required for the shifter to go from a 260/6 to a 265/6. The dimensions of the shift linkage are different IIRC.
When I put in a Z3 shifter into the M535i with a 265/6, we had to use the newer shift fork (E30 parts which is 260/6 based architecture). In order to make it fit we had to cut down and re-weld the shift fork to fit the connection points on the 265 and E28 shift console.
It might be totally different with the Autosolutions parts, but careful measurements need to be taken in either event.
What confuses me about this is the 265/6 I have came out of an E28 (85 535i). The only difference should be sheet metal vs aluminum console, right?vinceg101 wrote: Oct 24, 2023 9:03 PM More research is required for the shifter to go from a 260/6 to a 265/6. The dimensions of the shift linkage are different IIRC.
Before I misquote things, I need to dive into my photos and confer with Ralph on why we had to do what we did.cek wrote: Oct 25, 2023 7:48 AMWhat confuses me about this is the 265/6 I have came out of an E28 (85 535i). The only difference should be sheet metal vs aluminum console, right?vinceg101 wrote: Oct 24, 2023 9:03 PM More research is required for the shifter to go from a 260/6 to a 265/6. The dimensions of the shift linkage are different IIRC.
I do know that I had to engineer a way out of a box of my own making by electing to stick with BMW parts for a short shift solution (using a Z32.8 shifter) on a 265/6 in an E28. Other products like that from Autosolutions would have been the solution as I think their shifter linkage worked this out (verify).
I have put a 265/6 from '85 e28 into '83 e24 and then into '88 e28. Yes, you need the console but also maybe the matching driveshaft. They are different lengths.cek wrote: Oct 25, 2023 7:48 AM
Ahhh. Good info. Good thing I kept the driveshaft from the car the tranny came from.tschultz wrote: Oct 25, 2023 7:22 PMI have put a 265/6 from '85 e28 into '83 e24 and then into '88 e28. Yes, you need the console but also maybe the matching driveshaft. They are different lengths.cek wrote: Oct 25, 2023 7:48 AM
There are different length sheet metal consoles as well betwix the 260/5, 265/6 for M30 and probably the early 528e too. Perhaps more sheet.
Beautiful work Charlie.
Good point Travis about the different console.
I don't know the 260/5 is weak per see, but it has that reputation. Part of the reason i know the swap information is because the 633 callaway turbo i swapped because 4th gear was totally missing.
I don't think it would be problematic to use one, and it will probably be helpful that you won't abuse it and that you will have a bit less power going through it at higher elevation in durango...
Last year I had a reputable shop carry out a M30B35 swap for my '88 528e. A few days after I dropped the car in the shop, I see a guy offering a 265/6 for sale, and he was based not far from the shop. I jumped in and within 2 minutes I had a lock on the trans. Drove to pick it up the next day, and dropped it at the shop. Trans supposedly came from an E24 635, and it was in very decent shape.
At the time, shifter consoles were not available at usual online dealers, and Ebay was a desert. Following your advice Charlie, I skipped other short-shifter options and directed my shop to get Autosolutions on the phone.
So, the guy from Autosolutions (Roland? Ronald?) offered, for a bit more money, to CRAFT a shifter solution that did not require a sheetmetal console, and he put together something that looks like a spatial armature. The guy took the project like it was a personal challenge to his capabilities, and boy did he deliver. Moral of the story is, for this specific issue, a bespoke solution can be achieved outside of parts availability. To me (at least) this makes me think this is how it feels to use made-to-measure shoes or Savile Row suits.
<3Foonfer wrote: Nov 03, 2023 12:49 AM Last year I had a reputable shop carry out a M30B35 swap for my '88 528e. A few days after I dropped the car in the shop, I see a guy offering a 265/6 for sale, and he was based not far from the shop. I jumped in and within 2 minutes I had a lock on the trans. Drove to pick it up the next day, and dropped it at the shop. Trans supposedly came from an E24 635, and it was in very decent shape.
Was in the Santa Barbara/SLO area this weekend. Reached out to Hans who sold me Vlad in 2013 (we've kept in touch).
We met up and had great chat.
I love the E28 community.
