Serious question sirs, ladies:
Why would I want to replace my 36 year old output shafts known to me as CV joints?
I’d appreciate a good reason to replace them with aftermarket parts (OEM are NLA). Mine are not leaking grease. Rubber not damaged. Just don’t want to get in there and gut them out: Clean them, regresase them, re seal them and all that jazz. I know am being cheap on this not clever but appreciate an educating answer please. [535i manual]
Output Shafts schooling
Re: Output Shafts schooling
I had not a single joint or even boot failure on my 535i when I sold it 10 years ago with 330K on it. In other words I'd just leave them as is until you notice a boot failure or feel they are making noise. I suspect many of the remans are just factory joints, cleaned and regreased, that weren't bad in the first place.
Leave them in if you don’t want to rebuild. I put some cheap ones in from rock auto and the boot on one failed within a year and sprayed grease all over my undercarriage. I ended up rebuilding the originals and putting them back in.
harrypalmer
Mike, Federico,
Thank you for taking the time. I’ll do what you say. Nothing!
much appreciated answers.
Jack
Jack
