FS: M30B35
alpinass
FS: M30B35
Post by alpinass »
Up for sale is a early M30B35. 9:1 208h.p./225 ft. lbs. torque with the correct bosses for an e28/24.
L&R Automotive Machine Shop hot tanked parts and preformed B35 head rebuild. Ireland Engineering provided the parts. The M30B35 was assembled by an reputable BMW engine builder.
Stamped all rods w/pistons for cylinder location.
Dis-assembled, hot tanked all parts. Inspected oil pump, crankshaft (zero wear), rods, pistons - Standard size for rebuild. Crankshaft installed with STD size main bearings. STD size rod bearings. STD size ring set on pistons. Head gasket set, upper/lower cover set. front/rear/cam seals.
Installed new oil pump chain, oil pump tensioner. and B35 gear. Installed B34 oil pan with oil level sensor.
B35 Cylinder head was pressure tested for pin hole and stress cracks - checked OK. Rebuilt - 3 angle valve grind, 264 degree camshaft, new seals. Front cover was machined to B35 head. New banjo bolts and crush washers. Head bolts torqued. Valves adjusted.
New Timing chain, tensioner and rail. Water pump installed see pictures.
B35 intake & valve cover blasted with aluminum media then, glass tumbled. Applied VHT Matte Clear. - *These parts are still at the shop*
$4,000
Motronic 1.3 wiring harness ready to plug&play in e28/24 and #179 ECU. Both items are available at an additional cost.
oil pump chain, tensioner
Carma_Cardan
Re: FS: M30B35
Post by Carma_Cardan »
Beautifully !
brownsw44
Re: FS: M30B35
Post by brownsw44 »
Concur --> beautiful!!
Location?
alpinass
Re: FS: M30B35
Post by alpinass »
Los Angeles area. Taking pics with B35 intake manifold and valve cover installed.
