I have spent the past couple weekends working on the car to get it back running. I put the megasquirt back in and wired everything up. I did some base line tuning and its running great. Actually, its running better than ever. Currently set up at 10PSI and running strong. New 02 Sensor, Crank Sensor, Poly Filled Diff mount, and another fresh oil change. I put about 100 Miles on it this past weekend and it starts, runs and cruises great.There is no evidence of pressure in the coolant or coolant in the oil that would indicate it needs a head gasket as I had mentioned earlier. Honestly, I just think it needs a coolant flush. I also installed some better seats and cleaned it up a little bit.
Obviously it still needs base lining and final tuning. I don't really want to sell it now that its running, but I just don't need 6 cars right now. So its got to go.
All of this for the low low price of $2800.
Just PM me for my number if you wish to discuss in more detail and I can give you a more in depth description of the cars needs.
I took a few pictures which have been added below. See link for more and some of the rust areas. Front floor corners at jack points are the worst spot. This is not a car one should be looking at if they want a candidate to drop alot of money into and make really nice but, its a really fun driver. This just might be the quickest e28 you can buy for $~3000.
Has flipped manifold top mount turbo and inter cooler. Mega squirt II worked on by Peter Florance. Nice 3 inch exhaust. Eibach Springs, Big Brakes. Good Short shifter, Black Sport interior. Car has some rust and dents but is not a total rust bucket. Would make a great street bruiser for someone. Euro Bumpers, Euro Headlights. I sent the Harness and MS box to peter Florance to go through and re-wire and inspect. He rewired the connection to the harness and tested the MSII box verifying its all in proper order.
http://s272.photobucket.com/user/Cooter ... bo%20535is
Here is the Ad from when I purchased the Car. Note that the car will be sold on no-name 6 spokes not T-stars. And that the spare parts mentioned in the linked ad no longer convey.
http://www.mye28.com/viewtopic.php?t=85 ... ight=turbo
