GREAT CAR! PLEASE CONTACT THE PEOPLE BELOW FOR QUESTIONS.
contact name:
Eddie
call or text:
☎ (786) 377-4331
ORIGINAL LINK:
https://miami.craigslist.org/mdc/ctd/d/ ... 71344.html
1988 BMW 535i B35 Swapped ALPINA B9 Inspired Assembled and tuned
RMC Miami is now offering this amazing BMW for your consideration. This e28 has been well put together BY MANOFIED RACING Serial # 012.
8,800 KM shown is how many miles are on the build. Car has never been in an accident spent almost its entire life until 2015 in California and has a clean carfax.
Factory Body is in great shape for the year that being said there are miscellaneous minor scratches rock chips and a touch up on the rear passenger door0
Body has been outfitted with Euro bumpers Euro Factory aluminum front valance, Alpina front spoiler. Alpina trunk spoiler, Alpina green blue striping
Alpina badges. Real staggered Alpina wheels 17 X 8. 5'S In front.17 X 9. 5'S in rear
Interior is just as nice and correct as the exterior. Alpina correct cloth front seats the power seats function properly with no issue.
Alpina cloth rear seats. Alpina steering wheel. Alpina instrument cluster in metric Km.
Alpina floor mats. Alpina dead petal. Custom VDO cluster. Separate VDO coolant temperature, Oil pressure, and voltmeter
Engine is a B35 3.5 Liter Blue printed and balanced. 10. 3. 1 Compression with Rossy pistons. H-BEAM Rods with ARP hardware.
Port and polished head, stainless steel valves, titanium retainers . Iski dual valve springs with 292 cam. Manofied Corsa billet adapters to bolt factory
E28 M5 Individual Throttle bodies. Manofied Corsa billet velocity stacks with filters. Manofied Corsa Individual coil packs. Manofied Corda distributor delit kit. Manofied Corsa stand alone plug and play ECU.
Drive train consists of 5 speed manual transmission. Aluminum flywheel. Race clutch kit and a 373 differential.
Brakes have been converted to 7 Series front caliper & rotors. E28 Factory rear calipers & rotors with steel braided brake lines.
Cooling system consists of Oem radiator, silicon rubber hose kit, Manofied Corsa billet thermostat housing.
Manofied Corsa inline thermostat and Moroso coolant reservoir.
Exhaust sounds amazing it consists of a mandrel bent 3 inch stainless steel piping with a magna flow muffler.
This exhaust is mated to Manofied Corsa headers TIG Welded SST Tubing.
Suspension has adjustable camber and fixed caster plates on the front. Manofied Custom built coilovers with billet top plates. Adjustable rear toe kit. Adjustable rear camber kit and all urethane bushings. 25mm. Front and 19mm. Rear Sway bars.
Car runs and drives good. Has a very steady idle and is very planted while driving. Has all the driving characteristics of BMW when they were at their peak. Watch the video below so you can get a feel for how nice this car runs and drives.
The clutch engages nicely and every gear goes in smoothly. The engine purrs like a kitten, loves to be revved out to red line and sounds so intoxicating that you just want to keep on pushing it and driving it.
See Video Below
https://youtu.be/FNC1hHLjrxY
Serious Inquiries call Eddie 786-377-4331 or Danny 786-291-3622
Follow us on Instagram for live updates! @rmcmiami
Can Ship (Insured) Anywhere Worldwide if Needed.
Located in Miami, Florida 33126
Financing Available with Approved Credit
Trades Always Welcomed (UP or DOWN)
