So a few months ago I replaced my oil pan gasket-I had a small, continuous oil leak. When I reassemble, I torqued all the bolts to the appropriate spec. I noticed a few weeks ago another leak. I finally get the car on the MaxJax and take a look-nearly all of the oil pan bolts are loose-such as finger tight. I recall that, when I went to replace the oil pan gasket, alot of the bolts were not tight at all. I didn't think about it, as the gasket was just a bunch of cracked, brittle pieces and couldn't have been offering up much in the way of an effective seal.
I plan to use a thread locker and re-tighten all of the bolts, one at a time. Any suggestions or comments? Thanks.
Oil Pan Question
SlickDizzy
Re: Oil Pan Question
IIRC the torque spec is in inch-lbs to prevent gasket deformation (during my B35 build I just mindlessly torqued up the pan by feeling once and ruined the gasket like a dumbass, and had to do it over again with a new gasket), so they will feel less tight than heavier duty fasteners, but they should not be finger tight.
Are all of the wave washers in good shape? I bought a bag and replaced all of mine as a few were cracked, if the washers are in bad shape it may not hold torque.
They do seem to loosen up for some reason, although not usually to the degree you're seeing. Locktite is good, as is a paper gasket. The cork ones seem to crack and leak as you're seeing, the paper seem to hold up much better.
I use Permatex 3 on the gasket. I soak all of the bolts in gas and wire brush them until super clean. Reassemble with blue loctite. I use a 1/4” torque wrench to properly torque these bolts and valve covers. Easy to over tighten low torque fasteners.
glowell222
Thanks everyone. I will take your suggestions, and use the blue loctite as well as replace the washers.
I went with the paper gasket as well.
