Front Air Dam M5/IS installation (how to)
Hi everyone !!!
I recently bought a used M5/IS front air dam (spoiler) for my e28. With it came along a metal bracket. Now I thought that this metal bracket is what they call the "valance" which is where the air dam attaches to until I came across a forum "for sale" topic where a valance showed a different picture.
Can anyone run me through how to install the air dam if I convert my standard 528e front bumper/fog light set up to an M5/IS air dam look. Does it mean that without the valance I am doomed ? Also, what is the role of this metal bracket that went with air dam ?
Please help, anyone ??!!
Les
Les
Search function....there is a file on the site here with pics.
please search before asking in the future:
http://www.mye28.com/tech/NA_spoiler_install.pdf
535is Fog lamps
Thanks V1cut, now it's fully clear to me how the air dam fits into my car. I need to purchase the left and right fog lamp assembly. Know where I can get them (second hand will do if you know anyone). Am here in LA area.
Just perfect...
V1, good link b/c it's the info I also need to install my iS dam to my 528e.V1cut wrote:Search function....there is a file on the site here with pics.
Thanks.
Re: 535is Fog lamps
Well, after I find some, I'll look for you...lesm wrote:Thanks V1cut, now it's fully clear to me how the air dam fits into my car. I need to purchase the left and right fog lamp assembly. Know where I can get them (second hand will do if you know anyone). Am here in LA area.
ihateposers
Some valance removal info here -
http://www.mye28.com/viewtopic.php?t=44005
pertinent section says:
Installation is reverse of removal.
I found that a lot more than simply wiggling the valance free was needed. The screws hold the valance in place, though the back edges near the wheelwells are also affixed with very strong body adhesive. There was no way in hell my US valance was going to simply "wiggle free." I ended up using a hand steam iron to heat the area around the adhesive, then wiggled, and then the valance released.To remove the valance, your will need to remove the grills and headlights. After removing the grills and head lights, there are 4? or 6? screws, I forget, on the front center support, two more on each side on the exterior of the car, and one more on each side under the car. Remove all those bolts and screws, then wiggle the valance free.
ihateposers
I wouldn't use self-tapping screws for the bracket. Once you get the spoiler "hooked" once on one of those parking stops you'll understand. I almost cried the first time it happened to me after I got the car back from the paint shop. It held on pretty tight but it got scratched!
I fear that if you just use self-tapping they are going to be pulled out and you'll be left with an hanging/dangling mess. Just get the M10 bolts with washers and nylock nuts and be done with it.
ihateposers
installed the is air dam today
thanks to levent @ guten parts for hooking me up with a killer deal on the frame and is air dam!
installed the frame first and then slid the air dam on. quite the silly install but its on there.
the bumper had a crack and when i stretched it to fit - it flexed a bit - hence the middle has some flex in it
Re: Front Air Dam M5/IS installation (how to)
The installation guide doesn’t haven’t the measurements for drilling holes. This link has a spoiler install but I don’t think it’s the IS air dam right? https://bmweba.com/eba-01-29-9-770-635/amp/
Anyone have the hole measurements for the airdam?
