Mmmmmm e46 seats.....
jjcarr
Post by jjcarr »
Huuuuuge improvement over the worn out sport seats, surprisingly easy to install:
D Unit
Post by D Unit »
nice! Was the install similar to installing e34 seats? I have e34 seats in mine but I wash they were black like yours.
jjcarr
Post by jjcarr »
Not sure how the e34's would differ, as I have not messed with them. But the front bolt holes actually line up perfectly, but the seats are offset too much to the inside of the car. So I used 2 small steel plates and drilled holes to put about 1" of offset, moving the seats outboard.
On the e28 the rear bolt holes are lower than the front, so I had to shim with washers.
D Unit wrote:nice! Was the install similar to installing e34 seats? I have e34 seats in mine but I wash they were black like yours.
Post by slammin_e28 »
jjcarr wrote:Not sure how the e34's would differ, as I have not messed with them. But the front bolt holes actually line up perfectly, but the seats are offset too much to the inside of the car. So I used 2 small steel plates and drilled holes to put about 1" of offset, moving the seats outboard.
Ooooo.....nice! :up:
skip535i
Post by skip535i »
Looks pretty good, actually! :up:
jjcarr
Post by jjcarr »
skip535i wrote:Looks pretty good, actually! :up:
Not quite a period correct look, the e90 seats actually fit the look of the car better, but these feel perfect and look it as well. Super firm and solid, and tons of adjustability. Plus, a little lighter than the stock power seats. That was one thing I liked about my e46, too bad the e90 sport seats aren't as nice.
Shawn D.
Post by Shawn D. »
Looks nice!
E28CFX1
Post by E28CFX1 »
I loved the sport seats my E46 coupe and always wondered what they would look like in an E28- looks awesome! Sadly, I'm addicted to my power seats even though they're heavier ;) Thanks for sharing!
Fox
Denver, CO
Slow_Ballin'
Post by Slow_Ballin' »
Wow, that actually looks very nice. My driver seat is falling apart and I need a replacement. Maybe this will be a viable option instead...
austin8753
Post by austin8753 »
:up:
CSBolger
Post by CSBolger »
How high do you sit?
jjcarr
Post by jjcarr »
CSBolger wrote:How high do you sit?
A hair higher than stock, but the height adjustability of these seats is larger than stock, so I can scrape the headliner if I want, or barely peep over the steering wheel. There doesn't seem to be any loss of height range, though I generally prefer to sit high so I haven't bothered to explore the lower extension.
jjcarr
Post by jjcarr »
BTW, the kicker is that the junk yard sold them to me for $80 each. When he quoted that price I had to work hard to keep my composure... :)
Slow_Ballin'
jjcarr wrote:BTW, the kicker is that the junk yard sold them to me for $80 each. When he quoted that price I had to work hard to keep my composure... :)
I dont think I woudl have been to do it lol
Super good deal you got there!
E28indenver
Post by E28indenver »
I just got a black sport set, power and heated. Wiring is straight forward thanks to the e36 guys, but the rear holes at least on the power seats are off a bit.
gtivalencia34
Re: Mmmmmm e46 seats.....
Post by gtivalencia34 »
jjcarr wrote:Huuuuuge improvement over the worn out sport seats, surprisingly easy to install:
Hi there,
How about the rear seats? Will the E46 rear seats fit in the E28?
I am thinking of doing the same thing as I have a full interior available.
Thanks,
sal
travisj
Post by travisj »
gtivalencia34
Thank you!!!!
Mine are powered so I hope the wiring wont be that complicated.
Thanks again!!!!
Love this forum
ElGuappo
Post by ElGuappo »
I have a set of powered E46 sport seats going into my 528, the wiring is far simpler than E32/34 seats.
Not sure why the link to E34 rear seats was posted, the E46 rears are different size.
Here is the link you want http://www.mye28.com/viewtopic.php?p=1031489
gtivalencia34
Thank you@ Elguapo :)
simonm11
Post by simonm11 »
anyone knows how to hook up the heated option? i got all the other power functions to work, it was a breeze, i just rewired the stock e46 harness into the e28. if someone could shed some light about it i will really appreciate it.
thanks in advance!
travisj
Post by travisj »
ElGuappo wrote:I have a set of powered E46 sport seats going into my 528, the wiring is far simpler than E32/34 seats.
Sorry, in my head, I remembered those as being E46 seats. Will the E46 rear seat fit?
ElGuappo
Post by ElGuappo »
No idea, I've never had a 3 series of any flavor. I have an E34 rear bench, and can see the issues. I would guess the E46 shares a similar construction method with a plastic tub/pan...
But I would love to hear from someone who's actually moved one around.
demetk
Post by demetk »
simonm11 wrote:anyone knows how to hook up the heated option? i got all the other power functions to work, it was a breeze, i just rewired the stock e46 harness into the e28. if someone could shed some light about it i will really appreciate it.
thanks in advance!
Shouldn't be too difficult. Are you asking about where to pull power or what wires to connect?
gtivalencia34
thanks in advance!
that would be helpful! Thanks in advance. Any photos or process will be great!
simonm11
Post by simonm11 »
gtivalencia34 wrote:
thanks in advance!
Basically how to make it work, i dont have the controls/switches from the e46 so i assume something needs to be retrofitted in there. i also dont dont want a "hack" job, the last thing i want is to get my butt on fire and then the car, hahahaha.
demetk
Post by demetk »
Aren't the seat heater switches located on the seat? That's where they were on the e34 seats I installed.
simonm11
Post by simonm11 »
demetk wrote:Aren't the seat heater switches located on the seat? That's where they were on the e34 seats I installed.
nope =( thats my dilemma, the e46 heated seats switches are in the center console under the radio. i think they have 3 diff settings (low, mid, high)
demetk
Post by demetk »
That's could be problematic since you don't know where the electronic interface is to control the heating elements. It could be in the seat or it could be somewhere in the car. I guess the ETM should shed some light on that.
On the e34 seats it was simply a matter of supplying power to the correct pins on the seat connector to get the heated seats option working.
Dubs
Re:
Post by Dubs »
Stunning - anyone need a kidney?
Dubs
E28CFX1 wrote:I loved the sport seats my E46 coupe and always wondered what they would look like in an E28- looks awesome! Sadly, I'm addicted to my power seats even though they're heavier ;) Thanks for sharing!
Fox
Denver, CO
