U.S. spec M5 Trunk badge placement?
I did a search and came up with some conflicting info on the placement of the rear badge. Can someone with an unmolested trunk clarify the measurements? Danke schön!
Mark 88/M5 Houston wrote:No document; actual measurement (as far as I know it is the original placement)
From the right edge of the deck lid to the right edge of the "5": 54mm
Space between the right edge of the "///M" to the left edge of the "5": 8mm
From the bottom edge of the deck lid to the bottom of the "///M" and the "5": 25mm
Blue Shadow wrote:The BMW repair manual specifies the exact location of the badge, but my manual from 86 does not have the ///M5 info, just the ///M and the numbers 'e' and 'i'.
For the ///M, bottom edge 22 mm up from the lower edge of the trunk lid and 51 mm from the right edge of the to the right edge of the. Since it is both right edges, you gotta know what that means.
Mark 88/M5 Houston wrote:28mm from bottom lip and 55mm in from the right edge of trunk lid. Also the space between the "M" and the "5" is 10mm.
Blue Shadow
Re: Trunk badge placement?
Post by Blue Shadow »
Does everyone that might be able to help you know specifically which model car you want to identify? Might want to add that little tidbit. Having that info in this thread with that title should make it easy for folks to find all the model numbers in one place. Not documented are the € cars and the M5. Being here, it is either the M535i or the M5, both not in the manual. The M for the € M535i is there but not the US modified dealer bought m slapped on in front of the 535.
Allowing for Harbor Freight's accuracy variance, here's what my car measured. To my knowledge this is original placement.
M535i badge placement is absolutely in the manual. Look at the page Chas posted.
Blue Shadow wrote:Does everyone that might be able to help you know specifically which model car you want to identify? Might want to add that little tidbit.
Done
ahab wrote:Allowing for Harbor Freight's accuracy variance, here's what my car measured.
Thanks Aaron.
Re: U.S. spec M5 Trunk badge placement?
I scanned the sheets from my e30 and e28 blue binders and no new info except the e30 M3 specs the distance from the M and the 3 at 9mm. This is interesting because Mark’s measurements were 8 & 10mm.
I’m guessing the factory had some kind of jig to place the badges but there was probably a fair amount of variation from car to car even with the jig.
I’m going to bring a micrometer to St Paddy’s and measure all the M5s. :)
I'm pretty dismayed that the 100k mile car which I thought had to be original due to the seemingly 27 year patina seems to be wildly out of spec. Just to add a little more info to the thread I measured the salvage M5 too.
socalM5
Post by socalM5 »
I will bring my m5 to the St. Patrick's day meet if you need another measurement
Pavel
Post by Pavel »
Did we get a consensus on the values?
I duplicated my M5 badge placement 3 years ago when I was refreshing it. Mine looked original, wore out, patina you know.
Looked at couple of other trunks, and now mine seems off to me. Spacing between M and 5 is too large in comparison to the other cars I have access to.
bigwave
Post by bigwave »
This debate is just the excuse I needed to hold onto a fresh set indefinitely and work on other projects, though still curious as well.
Factory brochure shows huge variations on spacing between M3, M5, & M6 http://car-cm.jp/brochure/bmw/m_series_1988_jp.html
bigwave wrote:Factory brochure shows huge variations on spacing between M3, M5, & M6 http://car-cm.jp/brochure/bmw/m_series_1988_jp.html
The "6" even looks crooked on the back-cover shot (left-side leaf, top page of scan). Maybe it's a rumply scan? But you are right - even the factory brochure shows variance in the gaps..... :?
I've been sitting on these emblems for over a year now, so I just said Phuket and went for it today.
Looks crooked.
