Euro 535i LS Turbo Build Thread - 7/10/19 Dyno update
Re: Euro 535i LS Turbo Build Thread
Damn.
This sounds like a car Kyle owns.
T_C_D
Post by T_C_D »
Update. Turbo never smoked again but the 2pc intake manifold split again and was leaking. Took a few weeks but I bought a LS6 factory manifold and got it installed last night. Hoping to be able to get some miles on it now.
Sexy.
Hffvdbl
Post by Hffvdbl »
That looks really good Todd
Strut bar wont work.
T_C_D
Post by T_C_D »
I finally have some seat time with everything seemingly working properly. I ordered 80lb injectors today because the 50lbers are maxed out by 5500rpm. Engine feels very strong. Much stronger than anything I have ever driven. Looks like it's going to be exactly what I envisioned. :D
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
T_C_D wrote:I finally have some seat time with everything seemingly working properly. I ordered 80lb injectors today because the 50lbers are maxed out by 5500rpm. Engine feels very strong. Much stronger than anything I have ever driven. Looks like it's going to be exactly what I envisioned. :D
Sounds great Todd, keep the updates coming.
That's awesome. Do you have plans on dyoning once you install the new injectors?
Shawn D.
Post by Shawn D. »
Awesome!
T_C_D
Post by T_C_D »
Hopefully end of next week.
stoney
Post by stoney »
What was the reason behind fitting the smaller stroke crank?
Do you plan raising the rpm ceiling?
At what boost are these turbos in their efficiency range?
T_C_D
Post by T_C_D »
stoney wrote:What was the reason behind fitting the smaller stroke crank?
I wanted the short stroke for fun. super safe rev limit is 7000 instead of 6500. Turbo is happy in the 8-15psi range for this motor.
T_C_D
Re: Euro 535i LS Turbo Build Thread - 9/15 Dyno Results
Post by T_C_D »
Nice weather this morning (78F). I went to a new dyno shop that specialize in LS motors but both of their tuners were absent so I was on my own. AFR in the mid 11s and timing is probably close. Boost not super smooth and tapered a little or it would have made more HP. That being said I am super happy with the result. The way this engine makes power is exactly what I wanted. Will be bumping the rev limit a few hundred rpm since it is so happy at 7000rpm. Plenty of room for more boost if I wanted but highly unlikely since the engine will make a lot more power at the dragstrip in cooler temperatures.
https://youtu.be/tJ9jK9gInxU
Mark 88/M5 Houston
Looks quite nice Todd; congratulations!
:clap:
Bill in MN
Post by Bill in MN »
It's time for that engine to get transplanted into my chassis.
Jelmer538i
Post by Jelmer538i »
Nice!
Bill in MN wrote:It's time for that engine to get transplanted into my chassis.
But doesn't your chassis reject transplants? :laugh:
hahahaha.
turbodan
Post by turbodan »
That dyno chart is beautiful.
T_C_D
Post by T_C_D »
turbodan wrote:That dyno chart is beautiful.
Thanks Dan. I spoke to the cam designer and he thinks I am missing a little power at 6500rpm. It should peak there, not be flat. I was able to finally plot the required airflow across the turbo compressor map and the turbo is undersized. Compressor is operating at 68% efficiency above 5500rpm. Both the compressor wheel and the turbine need to be a little bigger. They are currently 67mm billet and P trim. This winter I'll go to 72mm billet and Q trim. The 72mm will be operating at 78% above 5500rpm. This will really help the top end. I think 535+ at a solid 10psi should be easily attainable.
offroadkarter
Post by offroadkarter »
Hey Todd, I do believe I came across your car on the internet
Source: https://www.flickr.com/photos/136164148 ... 8575261346
Wow! That is some terrific power!
Bill in MN
Oh now aren't we cute :laugh:
Nice job Todd!!!!
Good & Tight
Post by Good & Tight »
Those #'s are without the turbo hooked up right..?
T_C_D
Post by T_C_D »
Good & Tight wrote:Those #'s are without the turbo hooked up right..?
Good & Tight
Todd was kidding about the turbo not being hooked up. It's a nice flat power band, just thought it would make north of 600 being an LS engine.
What psi was that dyno run..?
T_C_D
Post by T_C_D »
It's a baby motor. 4.8L with big bore, 9.5CR at a little less than 10psi. It's making exactly what it should. About 20-23rwhp per psi of boost. 5 more psi and it's way over 600rwhp but I doubt I'll ever do that. My intention is to optimize the current setup and tweak the boost a tiny bit. It drives so great I doubt I'll ever chase a dyno number.
mkoepp
Post by mkoepp »
You have one sweet ride there Todd. A pure thing of beauty and a sleeper too......Congrats....
