New addition to the fleet
Tammer in Philly
Re: New addition to the fleet
Post by Tammer in Philly »
Karl Grau wrote:
davintosh wrote:Your other cars are gonna get jealous of the new girl.
I put 'em out to pasture. :)
Got some new mats. The ones that came with the car weren’t horrible but they’re the ones that left the factory with the car 15 years ago.
The 1.2 Bar radiator cap came today along with the DISA valve upgrade.
Also, a 12v recessed cigarette lighter charging port for the trunk and a USB charger for the cockpit. I don’t know exactly where either is going yet.
Image[/quote
File under "things you can do with nice cars in SD that don't work in Chicago."
By the way, I'll be in SD Weds. evening this week. May have time for a drink if you'd like to meet up.
-T.
Tammer in Philly wrote: By the way, I'll be in SD Weds. evening this week. May have time for a drink if you'd like to meet up.
I'm going to be in Perris for a pointless training seminar and I'm not sure when I'll get back to civilization. What part of town are you staying in?
Tammer in Philly
I saw your PM before this, but to broadcast the info I'll be in La Jolla, one night only (then a redeye back on Thursday evening, FUN).
-t.
The rest of the stuff to do Chris Kohler's crazy M-Tech bumper idea are here. The quotes I'm getting to paint the primered bumper Stahlblau Metallic are making me cry like a little girl though.
I stopped by the shop that did the maintenance all of its post warranty life. He gave me a summary of what's been done the last 5-8 years but he didn't want to give me a copy without the PO's permission.
The sources of my oil leaks are the oil filter housing gasket and the valve cover gasket. I'll do them both next weekend along with the DISA upgrade. I'm also going to do new tensioners, idler pulley, and serpentine belts.
It wasn't a 100° today so I decided to go ahead and do the DISA upgrade from German Autosolutions. It's a very well made part with easy to follow (online) instructions. I'm pretty sure it had never been touched since it left the factory.
muleskinner
Post by muleskinner »
Karl Grau wrote:It's not the year or exterior color that I wanted
Hey now....not to hijack the thread, but ain't nothing wrong with stahl blau
I have some hunting idle issues on my new-to-me E46. Thanks for the reminder about the DISA and I also grabbed the cooling system cap for my order.
How much time did the DISA upgrade take you? I read through the instructions and it looks straightforward, just a lot of steps and small parts to work with.
Adam W in MN wrote:I have some hunting idle issues on my new-to-me E46. Thanks for the reminder about the DISA and I also grabbed the cooling system cap for my order.
The idle on mine bounces too, and the DISA valve didn't fix it (the fix took me a couple of hours, including the time to take the valve off the intake, and I kinda dawdled.) I've heard from a few sources that the CCV/Oil Separator is the likely culprit for the idle issue, so that's next on my list.
I think there is a little more room to work in the e39 engine bay so it only took me about an hour. If I had to do it again, now that I know what I'm doing, I think it could be done 30 minutes or less no problem.
davintosh wrote:I've heard from a few sources that the CCV/Oil Separator is the likely culprit for the idle issue, so that's next on my list.
I hope I don't have to deal with that until I see what G.A.S. rolls out as their 'upgrade'.
There have been a few intrepid souls who have replaced the stock M54 CCV/oil separator with a PVC valve and a catch can and had great results; no change in performance and less oil consumption. I'm not sure if I want to go down that road though.
I was just going through some of my bookmarks on the CCV system and ran across this one again; How to test the CCV System. Totally forgot about that one; definitely need to go through that before spending the coin on a new valve and hoses.
That's a great link. It doesn't look like fun though, I hope I never need it. :laugh:
I got the serpentine belts, tensioners and aluminum water pump pulley today. The pulley is “Uro” brand which I wouldn't normally buy but I figure it is still better (and cheaper) than an OEM plastic pulley.
I didn’t want to use Victor Reinz gaskets and AutohausAZ doesn’t sell Goetze so I ordered a Goetze valve cover gasket and a BMW oil filter housing gasket from Pelican. I ordered a few other “while you’re in there” items and in my cart next to each item it said “in stock, ships tomorrow”. Since I ordered on Sunday, “tomorrow” meant yesterday. By noon today I’d heard nothing since placing the order so I checked the status and two 50 cent plastic rivets that hold the fan shroud were “on order”. I sent them an email and said, for the love of God, please tell me you aren't holding the entire order up for these two rivets. The reply was, “it turns out they are not in stock and we have no ETA for them”. So I told them to PLEASE cancel the two 50 cent rivets and ship the rest of the stuff.
Even though Pelican is always higher than Autohaus, I buy from them because I want to support California businesses but for fucks sake, if I hadn't contacted them, how long would they have let my order sit?
The rest of the stuff for “Operation Fuck You Oil Leaks” came today. There is definitely a difference between the feel of the Victor Reinz oil filter housing gasket and the BMW one.
I decided to replace the water pump too since I’m going to have everything removed anyway. I had planned on using the EMP Stewart pump but after further research decided against it.
I got a late start so I only did the valve cover gasket today.
The old one was in pretty good shape and I might have gotten away with just tightening the bolts which didn't seem like they were torqued down enough. Oh well, it's water under the bridge now and I wanted to check the spark plugs anyway. :)
The key to putting the cover back on has always been to bungee the wires and hoses out of the way by the firewall. The Greeks knew it, the Carthaginians knew it, now you know it.
I started on the oil filter housing gasket today. I'm doing belts, tensioners and water pump too. I was also going to change the diff oil but for some reason I don't have a 14mm hex to remove the drain & fill plugs. A 14mm hex is apparently too exotic for Pep Boys or Autozone and Harbor Fright you have to buy a whole set for $29.99. I might try Sears tomorrow but last time I checked their tool section, it was more picked over than an '80s era Moscow department store.
I bet Ace Hardware (or most any big-box hardware store) would have machine bolts with 14mm hex heads and a couple of matching nuts. Maybe even a 1/2" bolt would do in a pinch.
And if that oil filter housing gasket proves to be stubborn, don't forget the best gasket remover ever:
davintosh wrote:I bet Ace Hardware (or most any big-box hardware store) would have machine bolts with 14mm hex heads and a couple of matching nuts. Maybe even a 1/2" bolt would do in a pinch.
Give me a little credit here, that was the first thing I tried. :laugh:
I got some mission creep going on. There was a half assed repair done to the fan shroud at some point and I don't think it's repairable a second time.
Also, it hasn't rained in like 50 years but we have some today. :roll:
There's the culprit. That gasket is hard as rock, I can see why so much oil was leaking out.
Karl Grau wrote:There's the culprit. That gasket is hard as rock, I can see why so much oil was leaking out
How long has it been since you've had something hard in your hand?
OcCoupe wrote:How long has it been since you've had something hard in your hand?
Not since I was sitting in your lap at St Paddy's.
Everything almost back together except I don't know where I can get a fan shroud on a Saturday afternoon. :cry:
You two!
I don't suppose we could swap cars for a week or two and you do all of this to mine :) ?
I forgot to mention that this is the first BMW I've owned where I couldn't get the fan off with mild pressure on a crescent wrench. I had to use the thin 32mm and also to make my own pulley holder tool (pay no attention to the right hand side).
vinceg101 wrote:I don't suppose we could swap cars for a week or two and you do all of this to mine?
Sure, but you might find that your Sport seats somehow turned into comforts. :)
So, the cheapest quote I've gotten for painting a new primered front bumper is $450.00. I don't know what I don't understand about automotive painting but I just can't see why it costs so much. :?
Changed the diff oil using the tried and true I.V. method. The old oil actually looked pretty good as it missed the catch pan and drained all over the concrete and floor jack.
I hate the smell of gear oil.
cek wrote:I hate the smell of gear oil.
You and me both. The synthetic seems slightly less offensive but that might be my imagination.
You know, you could get more exposure for your updates by posting a thread about the task you are doing, then also posting in the "What did you do to your other cars today?" Thread. Then circularly reference everything too.
Karl Grau wrote:I got the serpentine belts, tensioners and aluminum water pump pulley today. The pulley is “Uro” brand which I wouldn't normally buy but I figure it is still better (and cheaper) than an OEM plastic pulley.
Just ordered a couple 'in stock' parts from pelican over the weekend. Monday's email told me the order had been transferred to their Ca warehouse. Wonder when they'll actually ship. Not griping, just a 'first timer' with them.
Karl Grau wrote:The old oil actually looked pretty good as it missed the catch pan and drained all over the concrete and floor jack.
I :laugh: about that. I hate Murphy and his damn laws.
I enjoy reading this thread and the numerous updates from someone else with dunn-right and while-we're-in-there disease.
wkohler wrote:You know, you could get more exposure for your updates by posting a thread about the task you are doing, then also posting in the "What did you do to your other cars today?" Thread. Then circularly reference everything too.
Just so you know, on Twitter, what you just did here is called a sub-tweet.
