Dieselboost's 524Compound Biturbodiesel
gazm3
Post by gazm3 »
Love this diesel build. Something different. Bet with all that lovely boost its great fun to drive. Sure it won't make the big power numbers the m30 turbo will make but the bottom end mId range torque will make it feel like a beast.
DieselBoost
Post by DieselBoost »
gazm3 wrote:Love this diesel build. Something different. Bet with all that lovely boost its great fun to drive. Sure it won't make the big power numbers the m30 turbo will make but the bottom end mId range torque will make it feel like a beast.
yep.... what i know sure is that 525tds can make 390bhp & about 700nm with inline injection pump
what im doing later is m21d28 stroker engine with inline injection pump.... i hope we can get 450hp out...
now my engine has about 300hp not sure... but i will find out it some day
DieselBoost
Just found another pic from past summer... this time i edited it little bit...
Willssy
Post by Willssy »
Where did you get your badges from I need to buy some new ones
DieselBoost
Willssy wrote:Where did you get your badges from I need to buy some new ones
I got mine from local official bmw shop from finland...
i think you can too get those from your bmw trader or service center...
Willssy
Post by Willssy »
How about a glow plug controller any websites you know where I can get one or any suggestions on a way I can bypass it.
DieselBoost
Willssy wrote:How about a glow plug controller any websites you know where I can get one or any suggestions on a way I can bypass it.
I bypassed my glowbox with 70a power relay with button...
i made new wires for the glow plugs too... old wires where in really bad condition
DieselBoost
While im in school for new job... im moving my garage to my apartment...
well my living room will be quite wild with all these stuff...
this is only a 1/10 of stuff...
DieselBoost
Re: Dieselboost's official 524td project pics
Something new for next summer....
Garrett T04B/E an compound friend for my masterpower
New shifter kit, i will modify shorter it a bit
60mm wastegate + two T03 flanges for new exhaust manifold
DieselBoost
Well my new project injection pump for my engine... yeah bosch inline injection pump with 10mm plugers and yes it is an bosch P-series pump and it is huge...
Globy
Re:
Post by Globy »
DieselBoost wrote:Engine timing for dumb people...
First check that your crank is on position O/T
next check that your cam is on this position...
use that square on cam to line it
Then try put your injection pump lock pin to place
Injection pump can be 180degrees wrong.. so if car does not start you can try to turn it...
and remember remove lock pin before you start :laugh:
I need to install a new pump on my e34, does the pump sprocket only have 2 positions?
How I know I'm installing the new pump in correct position, to start the car?
DieselBoost
Actually with good luck :D well if you put it wrong, it only starts hardy and makes white smoke and does not take RPM... nothing serious...
if im right there are two pin holes in pump wheel.... one is smaller than other one.... i just dont remember which one was the right...
JanisH
Post by JanisH »
Hello,
What injectors You Used?
DieselBoost
JanisH wrote:Hello,
Stock... no need for bigger injectors... and in future with P pump still stock ones.... because engine will stay indirect injection model, not an direct injected.
DieselBoost
Here us few new pics from our new garage... (my friends former cattle shed)
Well just receiveid "new" mig
DieselBoost
DieselBoost wrote:Here us few new pics from our new garage... (my friends former cattle shed)
My new short shifter
Pic from the garage, notice white w123 turbodiesel on background
Me dismantling transmission (yep on the floor today)
Our "new" mig welder
DieselBoost
The mighty M21d27 project engine
Post by slammin_e28 »
Ohhhh myyyy.....I am totally on board to see this D27 build up!
DieselBoost
I got new wheels for my td...
Japan Racing JR9 17x8.5 ET20
DieselBoost
Boskowalski
Post by Boskowalski »
I am amazed at your 524 :bow:
A question. I hope to get a mechanical pump installed in my 324td. Do I have to also change the turbo?
Continues to report, much encouragement!
DieselBoost
Boskowalski wrote:I am amazed at your 524 :bow:
you can use stock turbo or you can go bigger....
cek likes this thread.
DieselBoost
DieselBoost
DieselBoost
New boost tubes, ready for painting.
totheredline
Post by totheredline »
Awesome!!!!
DieselBoost
New oil lines for turbos
This will be new engine oil pressure gauge, because old one in console is replaced with another boost gauge (there is two boost gauges to LP turbo and HP turbo and exhaust pressure gauge...
DieselBoost
DieselBoost
Here is finished product.... i call this engine, biturbo evolution 1.0
