Cleaning an Intake Manifold
Any suggestions on the best most effective way to clean the inside of the Intake Manifold?
Right now I've got it soaking in a 55 gallon trash can with a lot of concentrated degreaser and water. I was using this to clean Oil Pans so I just dropped it in to see how well that does first. I suppose I'll hit with the stiff bottle brushes once it dissolves the carbon.
I'm trying to stay away from brake cleaner; I've been using gasoline to final clean the Oil Pans and would like to hang onto at least some brain cells (I've got so few left).
Given that I would be the one who would have to replace said dishwasher, consider it never heard. (Not a bad idea though, right up there with using an oven for sweating bowling balls and powder coating).RonW wrote:Dishwasher? If you're married I never said that and you never heard it.
Never would have thought of that one. I'll see if I can find some locally at the commercial kitchen supply houses.craigb93 wrote:Urn Cleaner for commercial coffee urns and pots with hot water is what many shops used to use.
Re: Cleaning an Intake Manifold
LIAR!!! You lie!vinceg101 wrote: (I've got so few left).
As a bowler and a wrench I need more appliances for the garage.vinceg101 wrote:Given that I would be the one who would have to replace said dishwasher, consider it never heard. (Not a bad idea though, right up there with using an oven for sweating bowling balls and powder coating).RonW wrote:Dishwasher? If you're married I never said that and you never heard it.
Soak your manifold in this stuff and it will come out clean, bright and looking like new inside and out. It will strip carbon, cosmoline, even paint and powdercoating off of your metal parts. It is not the cheapest stuff, but will last for years for cleaning all your parts.vinceg101 wrote:Any suggestions on the best most effective way to clean the inside of the Intake Manifold?
http://www.berrymanproducts.com/product ... s-cleaner/
Even it was a small split or groove, the ball is ruined; even a minor change in the exterior coverstock surface radically changes the balls' performance.wkohler wrote:My bowling ball split right down the middle a couple years ago. Haven't bowled since. I thought about mixing up some filler and filling the split as its a $300 ball.
After some more research, it turns out RonW and craigb are onto the something. Instead of people using the Urnex Urn cleaner (a tad expensive considering how much I'm going to need), people use dishwasher detergent in hot water or hot vinegar to clean stainless steel carafes. Evidently it's almost the same ingredients in both and works almost entirely by itself without any hand-work. Of course that is for coffee stains on a smooth stainless steel and the manifold is 25 years of carbon on rough cast aluminum, so I'm bound to be scrubbing anyway.
I'll look into the Berryman, they make a California compliant formula and sell it the local O'Reilly's. You're right though, it isn't cheap: a gallon is $25. But I have a lot of parts that could probably benefit from this stuff.
Yeah, I know. The ball was ruined when I bought it as for some reason they drilled it basically on the pin, so my ball with my super special over-reactive coating acted no differently than a house ball.vinceg101 wrote:Even it was a small split or groove, the ball is ruined; even a minor change in the exterior coverstock surface radically changes the balls' performance.wkohler wrote:My bowling ball split right down the middle a couple years ago. Haven't bowled since. I thought about mixing up some filler and filling the split as its a $300 ball.
Either way, I was soured by the experience. I also have no time to sleep let alone bowl.
I really think I was on to something with the hot tank at a machine shop.
Yeah, but then I have to track one down that's not clear across the city, find one willing to do this, take the time out of my day during the week, etc.wkohler wrote: I really think I was on to something with the hot tank at a machine shop.
In the end, it may be easier and cheaper to do the work myself.
I might try the radiator shop, there is one nearby. But I didn't have any luck there with the fuel tank welding so I'm not holding my breath.craigb93 wrote:The urn cleaner was what they used at NAPA shops for their aluminum hot tank.
A radiator repair shop can probably do the same thing.
For the amount of Urnex I might need, robbing the Cascade packets from the giant tub of them in the Kitchen will be far less expensive.
But then again, I have a pile of engine parts, valve covers, brackets, etc. that need cleaning, so maybe the Berryman's might be the way to go.
I don't know; still researching. Thanks for all the input so far.
Believe me, I know TSP. Lost much skin one summer cleaning and painting houses. You have to look pretty hard for the real TSP here in California; they've replaced it with some sort of substitute which mimics it, but lacks all the raw power the real stuff. I actually might have a box of it on a shelf somewhere; forgot about that stuff.
Not to digress, but I won't step foot in a Wal-Mart if I can help it. [I know, I know, it's kind of hard for me to take the moral high ground when I frequent HF. But I've been opposed to W-M's business and development practices long before I ever stepped foot in a HF.]
- Location: Back U.P. North,. Where the water's blue, the wind is free and seasons four.
My bad here, in my mind Mal Mart and Home Depot are nearly the same place.wkohler wrote:Or you could go to a real store and get that too. Paint departments at Home Depot and Lowe's have that also. TSP, but as someone who has done painting before, you know that.
The stuff at Wal-Mart probably has lead and melamine in it.
I did in fact mean Home Depot
