enabler...Duke wrote:10psi or your don't have a hair on your ass and wear a skirt.
Euro 535i LS Turbo Build Thread - 7/10/19 Dyno update
FirstFives Dictator
FirstFives Dictator
Made some improvements to the cooling system as it wasn't optimized and the car ran warmer than I wanted when it's 85+F.
Installed a 2nd electric fan, built a shroud for the top and bottom and installed a proper expansion tank. The shroud is temporary and will be replaced with something more elegant during a trip to Sweeney's.
There is less than $1750 in the entire motor and the shortblock can be replaced for $7-800 easily.Shadow wrote:That's sucks man but you got to keep the engine sorta
reliable. Can't be pushing limits on an expensive build.
I have decided to refine the entire package instead of just cranking up the boost.
M. Holtmeier
I agree but the chassis is already sorted out. The tune on the engine is really good. Mostly need to refine the power delivery which should not be that difficult.M. Holtmeier wrote:In my experience; turning up boost was easily accomplished within the first 2 months, refining the package has been an 6 year ongoing process.T_C_D wrote:
Todd
Update
Thankfully moving back to Milwaukee in 4 weeks! Cannot wait to get back to the land of nice people, good football, great beer, great weather and convenient drag strip.
Drove to TedFest. Was a great event as usual. Gave Ted a ride in the car which resulted in a noisy rod.
Not a complete surprise considering the engine went abt 45 seconds without oil pressure during one of the first drives. Don't know what caused it and it never happened again but obviously caused bearing damage.
Faced with a big $$ tow back to NYC, I treated the car nicely and drove it home. Couldn't hear any knocking with the windows down at 70mph.
Some good news. Cooling system is working great! Temps never exceeded 195F while waiting 20+ minutes at the border. MPG was 26.7 for the hwy portion of the trip.
I spent a week researching what to do for another motor and decided on something a little different. Shortblock was ordered yesterday.
aluminum block
manley oil pump
83mm crank
99mm bore
forged pistons
9.5CR
313ci of high revving V8. Peak HP will be abt 6500rpm with a 7000rpm redline.
Also going to have my heads rebuilt and CNC ported. Install scheduled for late Sept.
aluminum block
manley oil pump
83mm crank
99mm bore
forged pistons
9.5CR
- Location: Back U.P. North,. Where the water's blue, the wind is free and seasons four.
T_C_D wrote:Update
Drove to TedFest. Was a great event as usual. Gave Ted a ride in the car which resulted in a noisy rod.Not a complete surprise considering the engine went abt 45 seconds without oil pressure during one of the first drives. Don't know what caused it and it never happened again but obviously caused bearing damage.
aluminum block
manley oil pump
83mm crank
99mm bore
forged pistons
9.5CR
Man! You like to drop bombs don't you!
Your moving back to Milwaukee? Really?
You lost a rod bearing? 45 seconds with no oil pressure?
You ordered a custom built engine?
You couldn't make this stuff up.
Congrats on the move (we all know how much fun that is
Details will be required! Will you get your old shop back?
Thats good news, is your wife retiring?T_C_D wrote:Thankfully moving back to Milwaukee in 4 weeks! Cannot wait to get back to the land of nice people, good football, great beer, great weather and convenient drag strip.
45 seconds!!!! You really need to find that issue as if it happens again, another toasted engine. My engine did not like Ted Fest either.....think it is those guys that their heads bobble when they talk.
Bill in MN
Damn, I thought *I* was good at rationalizing things and making lemonade out of lemons.T_C_D wrote:It is what it is. I am certainly not happy about the timing but I am keeping this car forever so it would have happened at some point anyway.unt0uchable wrote:Doesn't sound like you are too devastated. lol
Bill in MN
Good & Tight
i did one for my 81 633 with autometer ultralite's, since then they have better fuel gauge's that can adapt to the sender in the car, don't be tempted by the ford unit if you see one listed, the range is almost perfect for the bmw sender at 12-75 ohm but from 50 on it reads empty on a ford gauge where the bmw unit reads the whole range
id post a pic of it but the hosting site its on has been down a week or two, tach and speedo on the outside and 4 in the middle in a square, make sure you have a large enough bulb to trigger the field in the alternator as a battery light, i used a small dome light assy taped up and outta sight behind the cluster parallel with the indicator (so all of the indicator lights would match and i wouldn't have one huge one)
Scottinva wrote:That looks good. I keep having issues with the stock stuff, been wanting to do something like that forever.
