ok.. eye candy ...take 2..
Crazy Croat
Post by Crazy Croat »
Skeen
Post by Skeen »
Nice, what kinda of wheels are those?
BTW, you're supposed to do burnouts until the stickers come off your tires. ;)
Crazy Croat
These are TSW Kayalami's but I changed the emblem which I think looks a lot better.
There is still time to burn off the stickers.. ;)
DRP535
Post by DRP535 »
Why do you guys stick the registration label on the driver's side of the windscreen? Doesn't that distract & annoy the living piss out of you having to see that all the time as your driving along?
Just wondering
Tammer in Philly
Post by Tammer in Philly »
[QUOTE="DRP535"]Why do you guys stick the registration label on the driver's side of the windscreen? Doesn't that distract & annoy the living piss out of you having to see that all the time as your driving along?
Just wondering[/QUOTE]
First question: morons write the laws here.
Second question: you get used to it pretty quickly.
-tammer <--lives in a state with moronic laws
Special
Post by Special »
nice
Shawn D.
Post by Shawn D. »
[QUOTE="DRP535"]Why do you guys stick the registration label on the driver's side of the windscreen? Doesn't that distract & annoy the living piss out of you having to see that all the time as your driving along?[/QUOTE]
[QUOTE="Tammer in Philly"]First question: morons write the laws here.
-tammer <--lives in a state with moronic laws[/QUOTE]
Unless you're a nearly-invisible senior citizen who can barely see over the dash, the sticker isn't in your line of sight anyhow.
ChronicX
Post by ChronicX »
Yeah, the stickers arent all that bad. how did that come up, can you even see it in the photo? Anways, awesome car, i love the wheels, they do look pretty nice.
Crazy Croat
Thanks. The car looks so much better dropped than it did before. Handles like a dream now.
unslow
Post by unslow »
Looks great! What suspension did you end up going with?
Crazy Croat
I went with Bilstein Sports all around with ST springs. Gives the car the very aggressive feel without overkill. So I can drive it pretty much anywhere without too much trouble. Very streetable IMO. Very happy with the set up.
Wiseguy
Post by Wiseguy »
Well in New Jersey that's just a safety inspection/emissions sticker (Like your RWC). Not all states work that way but about 10-15 that I can think of do. In some states it's the registration sticker there, in some states it's a small decal on the license plate..etc.
Dan_DS
Post by Dan_DS »
I like the drop...you have it sitting at a perfect height IMO
DRP535
Post by DRP535 »
I concur. Perfect ride height. Good rule of thumb is drop the rear until the bottom on the arch is exactly level with the top of the tyre and then drop the front to the equivalent height keeping the same rake. Never fails to look good.
Dinan e28
Post by Dinan e28 »
Looks great , I like the roundel caps.
Crazy Croat
Thanks guys. I did a ton of research before picking out the suspension and got some help from Steve Haygood. Of all the options out there for springs, this was the ideal choice. The other would have been M-tech springs but I understand these ST springs are slightly firmer. Others have said that Koni fronts and Bilstein rears were the way to go but I wasn't liking the idea of mixing brands so I stuck with Bilsteins all around.
For the caps, I ordered them through Bavauto. Turns out there are 60mm emblems out there so I took off the TSW and put the factory emblems and it made a world of a difference in looks.
DRP535
Post by DRP535 »
Good move sticking with same brand all round. FWIW you made the right decision not going with the M-Tech. I've just sold the M-Tech springs that came out of my M535i so I know what I'm talking about.
The M-Techs would be about 20mm (3/4") higher than what you have now *and* they'd be a harsher ride too I'm guessing. Mine were. Going slightly lower forces the use of a progressive spring which the M-Techs aren't. That gives you better small bump insulation whilst stiffening up when you push it. The M-Techs by contrast don't look as good, transmit more of the small bumps and then wallow, pitch and roll when you push it.
