Page 1 of 3
E28 M5 Dyno runs.... modified engine. Added photos 1/11
Posted: Aug 25, 2010 2:41 PM
by M5BB
Well I finally got to the dyno to tweak my moded engine that I rebuilt 2 years ago. Wow time flies.
This engine has CP pistons and rings that are 11:1 (approx)
The exhaust side of the head was cleaned up. (ported)
The cams are from a S38 B36 M5 engine (E34) and are at factory settings. No retard or advance.
Stock rods, crank and valves.
Euro headers.
Miller MAF and tunable WAR chip.
UUC exhaust and VSR1 Cats.
Stock ignition, injectors and FPR.
With the high compression we had to remove some advance from the GENII Miller MAF chip to prevent detonation.
But because this engine breathes so well the output was right near my target. I was hoping for 300RWHP.
As you can see from the Dyno graphs I got 294.57 RWHP and 258.42 torque.
This was on a Dynojet at Balanced Performance in Sugar Hill GA and was tuned by Ed Senf a professional tuner that is currently the tuner for the Rum Bum BMW Continental Tire car. Has also done Bimmer World and some Turner BMW's.
The drivetrain loss percentage they use for this vintage BMW and the Dynojet is 17%. Run those numbers and you get
344.64 HP at the crank and torque is 302.35
I'm pretty happy with that for a normally aspirated engine.
This is really just an M88 Euro with better pistons and some head work with modern maf and tuning.
Here's the link.
You are hearing the UUC exhaust too.
http://www.youtube.com/watch?v=bhHOvq3FSTs
Couple shots at the Dyno- Added 1/11
Ed tuning with the laptop and the WAR chip.
Posted: Aug 25, 2010 2:56 PM
by mooseheadm5
Now THAT is about what I am talking!
Posted: Aug 25, 2010 3:45 PM
by Tucker
Excellent! Cool to hear you had Ed do it, his tuning abilities were always well regarded in World Challenge. Were they actually able to calculate driveline drag on rolldown?
Posted: Aug 25, 2010 3:48 PM
by Randomg
Very cool, I have something to shoot for some day.
Posted: Aug 25, 2010 6:11 PM
by Matt
wow!!
you have videos of the runs with good sound? does the car sound glorious?
Posted: Aug 25, 2010 6:22 PM
by Philo
Very Nice.., let' see if I can beat your numbers !
POST THE VIDEO !!!!!!!!!!!!!!!!!!!!
Posted: Aug 25, 2010 7:07 PM
by ElGuappo
I bet it sounds like Efficient German Sex...
Re: E28 M5 Dyno runs.... modified engine.
Posted: Aug 26, 2010 9:28 AM
by Mark in Toronto
M5BB wrote:The drivetrain loss percentage they use for this vintage BMW and the Dynojet is 17%. Run those numbers and you get
This is really just an M88 Euro with better pistons and some head work.
Gary, you should be really happy with those numbers. Thanks for sharing and in the future I will add some numbers from my car. Mark
Posted: Aug 26, 2010 11:45 AM
by Eddie in TO
Thanks for sharing that information. Those figures are sure impressive for an e28 chassis. It must be a real hoot!
Mark in Toronto wrote:M5BB wrote:The drivetrain loss percentage they use for this vintage BMW and the Dynojet is 17%. Run those numbers and you get
Mark,
It would be interesting to see how strong those MM engines are.
Have you dynoed the badboy yet?
If not, I'd be interested in running the E12 through the dyno as well to obtain giggle figures.
Posted: Aug 26, 2010 12:33 PM
by Mark in Toronto
Eddie in TO wrote:Thanks for sharing that information. Those figures are sure impressive for an e28 chassis. It must be a real hoot!
Mark,
Not yet Eddie. Possibly before the end of this year's driving season, just as long as my MM motor does not blow up before the snow flies. Hahahahahahahahahahahahahahahahahahahahaha
And as I said before, Gary should be very please with those numbers.
Posted: Aug 26, 2010 1:19 PM
by M5BB
Thanks guys for the compliments.
I am very pleased and the car is a blast to drive.
Hopefully by the end of the day i will have the video on
YouTube.
I loaded it the other day but it seemed like it was not running correctly but this is the first time i have put anything on YouTube. My son told me you have to wait a few hours to view it. I just uploaded it (took and hour) so give it a chance and i will post the link.
Tucker asked about the driveline drag. They can't actually calculate it but use factors for different cars and dynos.
Like the E-28's have two piece drive shafts and half shaft axles.
All those joints add up.
The accepted number is 16-17%.
This has been discussed quite a bit on Bimmer Forums.
I knew Moosehead would like those numbers.
Posted: Aug 26, 2010 2:21 PM
by M5BB
I just added the link to the You Tube video to my original post above.
I'll put it here too.
Enjoy
Posted: Aug 26, 2010 2:31 PM
by Matt
Look, as far as I am concerned, _every_ S38B35 owner should do this.
If i understand correclty:
- high comp pistons
- stock euro headers
- "light" headwork ?
- stock B36 cams
- remove the AFM, go to customized/standalone EFI
- open up the exhaust a bit
You are making _90_ hp over stock numbers!
This has me completely re-thinking what i want to do with my (rear ended, still not repaired) M5.
Posted: Aug 26, 2010 2:51 PM
by Eta power
WOW, that is hot! Sounds great, keep up the good work!
Posted: Aug 26, 2010 9:17 PM
by RoyW
That sounds about right... my M5 track car dyno'd (a few years back) at 289 at the wheels (don't remember the torque). It's a S38b36 with euro headers, no CAT, B&B exhaust, 272 Schrick cams, lightweight fly, etc. Lots of fun!!
-RoyW
Posted: Aug 26, 2010 9:18 PM
by Tucker
Sounded great! I really wish you hadn't shared this because now I want to take my engine apart.
Posted: Aug 28, 2010 3:29 PM
by GaAlpinaOwner
Very nice Gary
Posted: Aug 28, 2010 10:48 PM
Sweet numbers.
Enjoy the ride...
Posted: Aug 29, 2010 12:36 PM
by klrskies
Very impressive results!
I'm wondering how much the lower compression stock U.S. pistons actually hurts top end HP if one has to take much timeing out though...?
The additional cam overlap from the b36 cams is probably helped a bit by the compression increase at low/mid range rpm's, but I can only get 93 octane locally at the pump...just wondering how much the high compression pistons are worth?
Ken
Posted: Aug 29, 2010 2:45 PM
by mooseheadm5
I would say that this amount of power would not be possible with everything but the HC pistons.
Paul Burke can make you lower compression pistons if you are worried about fuel quality.
Posted: Aug 29, 2010 5:00 PM
by Rich Euro M5
klrskies wrote:Very impressive results!
The additional cam overlap from the b36 cams is probably helped a bit by the compression increase at low/mid range RPM, but I can only get 93 octane locally at the pump...just wondering how much the high compression pistons are worth?
Ken
93 octane US fuel (Ron + MON / 2) is equivilent to European 98 octane RON (Research Octane Number). So 10.5:1 should be fine on 93 octane pump premium. If you can get Sunoco where you live even better, it's 94 octane.
Rich
Posted: Aug 29, 2010 6:34 PM
by Matt
assuming you had full standalone (a megasquirt), what's the highest static compression you'd run on an S38 B35 if the best gas you could get was 91 octane?
is 10.5 too high? What bout 10.2? Would it make more sense to stick with 10.5 and then plan on keeping octane booster in the trunk?
Posted: Aug 29, 2010 6:52 PM
by klrskies
This is quite impressive. What compression ratio could be used with a high grade methanol content E85, and with that fuel, what output could be achieved on a similar engine, set up for that fuel?
Ken
Posted: Aug 29, 2010 7:45 PM
by paul burke
The additional cam overlap from the b36 cams is probably helped a bit by the compression increase at low/mid range RPM.
Ken
Overlap has very little to do with building low and mid range torque, however a retarded intake cam or a late intake closing has everthing to do with it. When you retard the intake cam (leave exhaust where it is) it decreases overlap yet kills low speed torque.
The longer you leave the intake valve open ABDC the more charge you give back to the intake tract in the beginning of the comp. stroke (This is positive pressure created by the piston, exhaust valve is already closed) which results in a lower dynamic running pressure and less torque. Static comp. ratio by itself does not dictate fuel requirements.
Paul
Posted: Aug 29, 2010 8:11 PM
by klrskies
Overlap has very little to do with building low and mid range torque?
One doesn't want a compression increase to compensate for the loss of dynamic compression from cams with increased overlap?
A fuels' detonation tolerance plays no part in determining compression ratio?
Wondering what could be accomplished with High content e-85?
Ken
Posted: Aug 29, 2010 10:22 PM
by paul burke
klrskies wrote:Overlap has very little to do with building low and mid range torque?
Ken
Lets start with this one. Why would you believe overlap significantly effects low and midrange torque? For discussion purposes lets say "low and midrange" equates to 1800-3800 rpm.
Paul
Posted: Aug 29, 2010 11:56 PM
by Black Steel
M5BB wrote:Thanks guys for the compliments.
YouTube.
Well done
I have read so much about updating these engines but have always come back to the fact that a compression increase is the best way. This is what the euro boys are doing
I have seen these engines being run as high as 12:1!
Most are well over 400bhp know!!
If you look at how BMW get the power out of the later six cylinder engines you will see that the compression ratio has increased with each application.
Cam wise you can stick all types of cam profiles in but 9 times out of 10 you always loose to much at the bottom end.
What people don't realise either is that over a certain cam profile the head has to be machined just so that the cam can turn
Your next step should be a carbon airbox
I already no what type of numbers you will get with one fitted.
There is a reason why I picked the b36 for my car
Posted: Aug 30, 2010 5:05 AM
by klrskies
paul burke wrote:klrskies wrote:Overlap has very little to do with building low and mid range torque?
Ken
Paul
OK, compression can be increased to compensate for lowered dynamic compression ratio due to overlap increase from longer duration cams, occuring in the rpm range where the cam/tuned intake systems are not in phase. Here's an intrersting calculator for the complex DCR...
http://www.kb-silvolite.com/calc.php?action=comp
One might be better off discussing cylinder pressure prior to ignition so as to account for more of the varibles.
And again, What does the forum feel is possible if hi ethanol content E85 were used? Lets discuss my question first...then go off on a tangent course, or launch an appropriate thread on the topic. The results of this build are impressive, and it leaves me curious what's possible with with E-85 and perhaps E-100 fuel. I'm sure you have a good idea whats required and possible for an engine built to use these fuels Paul.
Ken
Posted: Aug 30, 2010 11:54 AM
by paul burke
Ken, study the calculator, the last entry is intake valve closing ABDC. Like I said in my earlier post the intake closing has much more influence relative to dynamic pressure than the opening (which is where overlap time occurs).
Have run comp. ratios over 15-1 on E85 but like I said static compression by itself is not the dictator.
Paul
Posted: Aug 30, 2010 4:52 PM
by Philo
- high comp pistons
- stock B36 cams
Agree.., but Gary's approach meant he had to tear down the engine and spend 8-10k to put it back together and add the mods.., the WAR Chip, headers, pistons, cams, etc... Most stock B35 owners wont rip into their engine for 90hp.. But will if it suffers from internal ailments like Gary's did.
I still think the best bang for the buck for a stocker is a custom burned chip. Anything more tends to turn into a slippery slop scenario. Taken from first hand experience of course.
I'm going down the same road as Gary but with a 86x95 platform. I hope I see better numbers...
